Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. iClicker cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Disassembling iClicker Device, Disassembling iClicker Device: adım 1, 1 resimden 1.
    • Behold the iclicker in all its interactive and educational beauty.
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling iClicker Device: adım 2, 1 resimden 1.
    • Place the device on a flat surface, buttons facing down.
    • Remove the battery cover and the three batteries within.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling iClicker Device: adım 3, 2 resimden 1. Disassembling iClicker Device: adım 3, 2 resimden 2.
    • Remove the two visible screws using a #00 Phillips screwdriver.
    • Oops! Don't forget a hidden third screw beneath the factory label.
    • Peel back the corner of the label to reveal the hidden screw.
    • If you wish to maintain the integrity of the label, a blowdryer may be used to soften the adhesive on the label before removal.
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling iClicker Device: adım 4, 2 resimden 1. Disassembling iClicker Device: adım 4, 2 resimden 2.
    • Depending on how much abuse your iclicker has endured, you might be able to separate the front and rear panels of the iclicker with your fingers.
    • For the more resistent iclickers, a spudger may be employed to separate the pieces.
    FixBot'a Sor
    Yorum Ekle
  5. Disassembling iClicker Device: adım 5, 1 resimden 1.
    • Your iclicker is now exposed for all its worth.
    • The back panel can be set aisde, as the remaining components are housed in the front panel.
    FixBot'a Sor
    Yorum Ekle
  6. Disassembling iClicker Device: adım 6, 2 resimden 1. Disassembling iClicker Device: adım 6, 2 resimden 2.
    • Using a spudger, gently pry the battery connectors from the front panel.
    FixBot'a Sor
    Yorum Ekle
  7. Disassembling iClicker Device: adım 7, 1 resimden 1.
    • If your circuit board is stuck in the front panel, use a spudger to lift the circuit board from the front panel.
    FixBot'a Sor
    Yorum Ekle
  8. Disassembling iClicker Device: adım 8, 1 resimden 1.
    • The buttons can be easily removed from the front assembly sans spudger.
    FixBot'a Sor
    Yorum Ekle
  9. Disassembling iClicker Device: adım 9, 1 resimden 1.
    • Don't lose the small LED cover sitting precariously in the front panel.
    FixBot'a Sor
    Yorum Ekle
  10. Disassembling iClicker Device: adım 10, 1 resimden 1.
    • Your iclicker is now disassembled.
    FixBot'a Sor
    Yorum Ekle
1Rehber Yorum
What is an iClicker ?
furbies - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 8,194
