Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
Prerequisite guide to remove the main housing from iP21 for repair.
  1. Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws. Unscrew the four 11mm screws from the base. Pry the base loose using the spudger.
    • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
    • Unscrew the four 11mm screws from the base.
    • Pry the base loose using the spudger.
    • Remove the base by hand.
  2. Remove the two black 6mm screws connecting the main circuit board to the housing top. Grasp front housing and back housing firmly.
    • Remove the two black 6mm screws connecting the main circuit board to the housing top.
    • Grasp front housing and back housing firmly.
    • Gently pull front housing from the back housing.
Sonuç
Brandy
601 İtibar
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 32
