Ana içeriğe geç
Giriş
This guide has been updated by iFixit staff! Read the new, official guide here.
  1. Using a 5-point pentalobe screwdriver, unscrew the 2 pentalobe on the bottom of the phone near the dock connector.
    • Using a 5-point pentalobe screwdriver, unscrew the 2 pentalobe on the bottom of the phone near the dock connector.
  2. Push the back glass towards the top of the phone.
    • Push the back glass towards the top of the phone.
  3. Android Tamir Setleri
    A new screen or battery is one kit away.
    Hemen Alışveriş Yapın
  4. Using a #000 Phillips screwdriver, unscrew the 2 very small Phillips screws.
    • Using a #000 Phillips screwdriver, unscrew the 2 very small Phillips screws.
  5. Using a plastic opener tool, pry up the battery connector shield. Be careful not to lose the smaller antenna connector shield under the top  connector sheild. Using a plastic opener tool, pry up the battery connector.
    • Using a plastic opener tool, pry up the battery connector shield. Be careful not to lose the smaller antenna connector shield under the top connector sheild.
    • Using a plastic opener tool, pry up the battery connector.
  6. Pull upwards on the plastic tab. If it's the first time, you may have to use the plastic pry tool on the outside (right) edge of the battery to loosen battery first.
    • Pull upwards on the plastic tab. If it's the first time, you may have to use the plastic pry tool on the outside (right) edge of the battery to loosen battery first.
    • Then, out pops the battery.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Chandler Skinner
3.721 İtibar
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 4
Her zaman: 5,941
