Ana içeriğe geç
Disassembling iPhone 4S Vibrator
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Disassembling iPhone 4S Vibrator, Disassembling iPhone 4S Battery: adım 1, 1 resimden 1.
    • Using a 5-point pentalobe screwdriver, unscrew the 2 pentalobe on the bottom of the phone near the dock connector.
  2. Disassembling iPhone 4S Vibrator: adım 2, 1 resimden 1.
    • Push the back glass towards the top of the phone.
  3. Disassembling iPhone 4S Vibrator: adım 3, 1 resimden 1.
    • Using a #000 Phillips screwdriver, unscrew the 2 very small Phillips screws.
  4. Disassembling iPhone 4S Vibrator: adım 4, 2 resimden 1. Disassembling iPhone 4S Vibrator: adım 4, 2 resimden 2.
    • Using a plastic opener tool, pry up the battery connector shield. Be careful not to lose the smaller antenna connector shield under the top connector sheild.
    • Using a plastic opener tool, pry up the battery connector.
  5. Disassembling iPhone 4S Vibrator: adım 5, 1 resimden 1.
    • Pull upwards on the plastic tab. If it's the first time, you may have to use the plastic pry tool on the outside (right) edge of the battery to loosen battery first.
    • Then, out pops the battery.
  6. Disassembling iPhone 4S Vibrator, Disassembling iPhone 4S Logic Board: adım 6, 1 resimden 1.
    • Disconnect the antenna cable from the logic board.
  7. Disassembling iPhone 4S Vibrator: adım 7, 1 resimden 1.
    • Unscrew the 2 phillips screws holding the shield covering the dock connector ribbon.
    • One of the screws is .2 millimeters longer than the other.
  8. Disassembling iPhone 4S Vibrator: adım 8, 2 resimden 1. Disassembling iPhone 4S Vibrator: adım 8, 2 resimden 2.
    • Disconnect the dock connector ribbon from the logic board.
    • Pull the cable up and flow it to the side.
  9. Disassembling iPhone 4S Vibrator: adım 9, 2 resimden 1. Disassembling iPhone 4S Vibrator: adım 9, 2 resimden 2.
    • Unscrew the 4 screws holding the large shield and the single screw holding the small shield.
  10. Disassembling iPhone 4S Vibrator: adım 10, 1 resimden 1.
    • Using the plastic opening tool, pry up the 7 connectors on the top of the logic board.
    • The back camera will come out, make sure you get the small piece of black plastic covering the back of the camera.
  11. Disassembling iPhone 4S Vibrator: adım 11, 2 resimden 1. Disassembling iPhone 4S Vibrator: adım 11, 2 resimden 2.
    • Unscrew the 2 flat head screws.
    • Unscrew the 3 phillips head screws, the top one is covered by a small piece of black tape.
  12. Disassembling iPhone 4S Vibrator: adım 12, 1 resimden 1.
    • Using your fingers or a plastic opening tool carefully pull out the logic board.
  13. Disassembling iPhone 4S Vibrator, Disassembling iPhone 4S Vibrator: adım 13, 2 resimden 1. Disassembling iPhone 4S Vibrator, Disassembling iPhone 4S Vibrator: adım 13, 2 resimden 2.
    • Pry the vibrator up off the metal.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Chandler Skinner
3.710 İtibar
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 2,483
