Giriş
This guide explains how to remove the bumper from your Roomba.
Neye ihtiyacın var
With a Phillips #1 screwdriver, remove the ten 12mm screws located along the bottom of the bumper.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Mine had a wire leading from the body to the bumper. The bumper end was held on by two small Phillips screws, which I undid to disconnect it (the bit it screws on to falls off the top of the bumper).
When putting it back together, make sure to put it on again the right way round, with the wire towards the front of the roomba (i.e. furthest from the main body), otherwise you will find the wire gets in the way of the bumper working, and you'll have to take it all apart again, like I did!
If all you need off is the faceplate, skip all of the screwdriver-based steps, and just remove the dirt bin(step 7) and start from step 11 at the rear.
David Forrest - Yanıt
