Ana içeriğe geç
Disassembling the Ematic Genesis
Neye ihtiyacın var
  1. Disassembling the Ematic Genesis, Ematic Genesis Casing: adım 1, 3 resimden 1. Disassembling the Ematic Genesis, Ematic Genesis Casing: adım 1, 3 resimden 2. Disassembling the Ematic Genesis, Ematic Genesis Casing: adım 1, 3 resimden 3.
    • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
  2. Disassembling the Ematic Genesis: adım 2, 3 resimden 1. Disassembling the Ematic Genesis: adım 2, 3 resimden 2. Disassembling the Ematic Genesis: adım 2, 3 resimden 3.
    • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
    • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
    • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
    • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
  3. Disassembling the Ematic Genesis: adım 3, 1 resimden 1.
    • Remove back plate from screen plate and lay both down flat next to each other.
Sonuç
Justin Rohrman
745 İtibar
6 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-3, Williams Spring 2015 Baylor, Team 4-3, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S4G3
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 313
