Ana içeriğe geç
Disassembling the Garmin eTrex Vista-H Outer Case
Neye ihtiyacın var
  1. Disassembling the Garmin eTrex Vista-H Outer Case, Removing Battery: adım 1, 1 resimden 1.
    • Flip the device to the backside, and locate the metal tab at the center of the back cover.
  2. Disassembling the Garmin eTrex Vista-H Outer Case: adım 2, 1 resimden 1.
    • Lift the metal tab up, and rotate it counterclockwise. This will unlock the back case cover.
  3. Disassembling the Garmin eTrex Vista-H Outer Case: adım 3, 2 resimden 1. Disassembling the Garmin eTrex Vista-H Outer Case: adım 3, 2 resimden 2.
    • Lift the battery plate off to either insert or remove 2 AA batteries.
  4. Disassembling the Garmin eTrex Vista-H Outer Case, Disassembling the Garmin eTrex Vista-H Outer Case: adım 4, 2 resimden 1. Disassembling the Garmin eTrex Vista-H Outer Case, Disassembling the Garmin eTrex Vista-H Outer Case: adım 4, 2 resimden 2.
    • With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
  5. Disassembling the Garmin eTrex Vista-H Outer Case: adım 5, 3 resimden 1. Disassembling the Garmin eTrex Vista-H Outer Case: adım 5, 3 resimden 2. Disassembling the Garmin eTrex Vista-H Outer Case: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • With the pick side of a spudger (or tweezers), peel the sticky tape from the device.
  6. Disassembling the Garmin eTrex Vista-H Outer Case: adım 6, 1 resimden 1.
    • Split the front and rear panels by inserting a small pointed tool (such as a pen point or a screwdriver tip SL1.5) in the 5 plastic tabs along the sides of the device.
    • Do not remove the back panels quickly. If too much force is applied, there is a wire connection that will break.
    • CAUTION! Be careful not to force the tabs inward. This will result in broken tabs.
  7. Disassembling the Garmin eTrex Vista-H Outer Case: adım 7, 2 resimden 1. Disassembling the Garmin eTrex Vista-H Outer Case: adım 7, 2 resimden 2.
    • With tweezers (or your fingernails), carefully disconnect the wires between the PC input and the motherboard.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Ryan Green
93 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 21-30, Regan Fall 2010 Cal Poly, Team 21-30, Regan Fall 2010 üyesi
CPSU-REGAN-F10S21G30
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 5,109
