Ana içeriğe geç
Disassembling the Nokia 6300
Neye ihtiyacın var
  1. Disassembling the Nokia 6300, Rear Cover: adım 1, 1 resimden 1.
    • Take off the back cover by pushing it down and sliding it backwards.
    FixBot'a Sor
  2. Disassembling the Nokia 6300: adım 2, 2 resimden 1. Disassembling the Nokia 6300: adım 2, 2 resimden 2.
    • Take out the battery, SIM card, and MicroSD card.
    • Unscrew the two T6 Torx screws.
    FixBot'a Sor
  3. Disassembling the Nokia 6300: adım 3, 1 resimden 1.
    • Try to seperate the front cover from the rest of the phone. The front cover is held by four plastic clips.
    • The first time you do this you may have to use some force but do it in a controlled way. If you break the plastic clips you'll need a new front cover.
    FixBot'a Sor
  4. Disassembling the Nokia 6300: adım 4, 1 resimden 1.
    • You can take off the keypad now, this is sitting loose on top of the sensors.
    • Unscrew the four remaining T6 Torx screws.
    • The screws holding the motherboard in place are different from the two previous screws which held the rear cover in place.
    FixBot'a Sor
  5. Disassembling the Nokia 6300: adım 5, 1 resimden 1.
    • The motherboard with it's screen are now loose, you can pop it right out.
    • If you've been using this phone for a while, there's probably some dust inside the back shell.
    • There's a lot of contacts exposed, so make sure not to damage those.
    FixBot'a Sor
  6. Disassembling the Nokia 6300: adım 6, 3 resimden 1. Disassembling the Nokia 6300: adım 6, 3 resimden 2. Disassembling the Nokia 6300: adım 6, 3 resimden 3.
    • There's your phone!
    FixBot'a Sor
Sonuç
20 farklı kişi bu kılavuzu tamamladı.
LucasJV
741 İtibar
3 adet Kılavuz yazıldı
1Rehber Yorum
in this where is bluetooth module plzz give me ans @ bhatia.abhi98@gmail.com
abhishek - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 18
Son 30 gün: 122
Her zaman: 25,241
