Giriş
Use this guide to disassemble an Asus N551JX laptop to gain access to the internal components.
Neye ihtiyacın var
Turn off the laptop.
Remove all USB connections and SD cards.
Turn the laptop upside down on a flat surface. Then, remove the battery by pushing the highlighted plastic slide to the right and lifting the battery out.
Remove all marked screws:
Five #1 Phillips screws
Two #0 Phillips screws
Slide the disk drive out of the laptop case.
Remove the screws marked in the photo:
Remove the rear housing by sliding it downwards, as indicated in the photo.
Use the flat end of a spudger to disconnect the connector marked in the photo.
Remove the hard drive (HDD) by unscrewing the marked screws and sliding the drive in the direction of the arrow.
Four #0 Phillips Screws
Remove the memory disk by gently pushing down the metal arms on the side of the disk.
Remove the WLAN module by disconnecting the antennas and unscrewing the screw marked in the photo.
#0 Phillips Screw
Start by inserting an opening pick in the corner where the headphone jack is located. Insert your pick between the two panels.
Continue by sliding the opening pick to the right.
Repeat these steps on the other two sides. Stick your pick in the corners on these sides as well. However, do not open the side of the case where the battery is located yet.
Insert your opening picks between the different parts of the case (example shown in photo) and make sure all the plastic clips are loose.
Turn the laptop 180 degrees.
Open the keyboard side of the laptop while holding the aluminium body.
Carefully move the aluminum body towards you.
Disconnect the marked connector by pulling the plastic pull tab straight up.
You now have gained access to the internal hardware of the laptop, and can perform any required maintenance.
Reassemble by following this guide in reverse order.
To reassemble the device, follow these instructions in reverse order.
7 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
3 Yorum
Thank you for this guide, I'd have struggled without it.
I had a bit of a dent where my power socket was, and it snapped the surround of the screw holding it in place, a replacement is £25 on eBay.
I figured instead of paying that I'd try using a glue gun to fill the void between the socket and the plastic wall behind it.
Also bizarrely my HDD was only held in by two screws, which is a bit strange as I don't think I've ever had this laptop repaired before.
Thank you very much fot this guide. It helped me a lot since after remving all screws I had no idea how to procede. Step 8 and 10 especially were helpful for me.
Thomas
So wheres Jumper or cmos ?
