Ana içeriğe geç
Display Assembly
Neye ihtiyacın var
    • Pull straight up on the pull-tab that is attached to the display-feed flex cable to disconnect the cable from the system board.
    • Disconnect the antenna cable.
    • Close the display.
    • Turn the computer upside down with the back of the computer facing you.
    FixBot'a Sor
    Yorum Ekle
  1. Display Assembly, Remove the Screws: adım 2, 1 resimden 1.
    • From the bottom of the computer, remove the two M2.5 x 8-mm screws labeled "D."
    FixBot'a Sor
    Yorum Ekle
  2. Display Assembly, Remove the Screws: adım 3, 2 resimden 1. Display Assembly, Remove the Screws: adım 3, 2 resimden 2.
    • From the back of the computer, remove the two M2.5 x 8-mm screws labeled "D."
    FixBot'a Sor
    Yorum Ekle
  3. Display Assembly, Removing the Cables: adım 4, 1 resimden 1.
    • Turn the computer right-side up and open the display.
    • Carefully remove the antenna cable and the display cables from their routing guides.
    FixBot'a Sor
    Yorum Ekle
  4. Display Assembly, Lifting the Display Assembly: adım 5, 1 resimden 1.
    • NOTICE: Be careful not to damage the display switch when removing the display.
    • Lift the display assembly out of the computer base.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Terrence15
80.125 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
2.003 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 25
Her zaman: 864
