Ana içeriğe geç
Dodge Durango 2004 Tail Light Bulb Replacement
Neye ihtiyacın var
  1. Dodge Durango 2004 Tail Light Bulb Replacement, Dodge Durango 2004 Tail Light Bulb: adım 1, 2 resimden 1. Dodge Durango 2004 Tail Light Bulb Replacement, Dodge Durango 2004 Tail Light Bulb: adım 1, 2 resimden 2.
    • Open the car's trunk.
  2. Dodge Durango 2004 Tail Light Bulb Replacement: adım 2, 3 resimden 1. Dodge Durango 2004 Tail Light Bulb Replacement: adım 2, 3 resimden 2. Dodge Durango 2004 Tail Light Bulb Replacement: adım 2, 3 resimden 3.
    • Pry both caps out using a spudger.
  3. Dodge Durango 2004 Tail Light Bulb Replacement: adım 3, 1 resimden 1.
    • Carefully pull the tail light towards yourself to gain access to the wiring.
    • Do not pull the tail light too far. It is still connected to the wires and moving it too far may damage them.
  4. Dodge Durango 2004 Tail Light Bulb Replacement: adım 4, 3 resimden 1. Dodge Durango 2004 Tail Light Bulb Replacement: adım 4, 3 resimden 2. Dodge Durango 2004 Tail Light Bulb Replacement: adım 4, 3 resimden 3.
    • Locate the connector and pull the orange safety pin out.
    • After the safety pin is out, pull on the connector plug to separate it from the tail light.
  5. Dodge Durango 2004 Tail Light Bulb Replacement: adım 5, 3 resimden 1. Dodge Durango 2004 Tail Light Bulb Replacement: adım 5, 3 resimden 2. Dodge Durango 2004 Tail Light Bulb Replacement: adım 5, 3 resimden 3.
    • Remove the three Torx 15 screws that are holding the bulb carrier in place.
  6. Dodge Durango 2004 Tail Light Bulb Replacement: adım 6, 2 resimden 1. Dodge Durango 2004 Tail Light Bulb Replacement: adım 6, 2 resimden 2.
    • Remove the bulb holder piece from the tail light by gently pulling it up.
  7. Dodge Durango 2004 Tail Light Bulb Replacement: adım 7, 3 resimden 1. Dodge Durango 2004 Tail Light Bulb Replacement: adım 7, 3 resimden 2. Dodge Durango 2004 Tail Light Bulb Replacement: adım 7, 3 resimden 3.
    • Remove the defective bulb by pulling it up.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 23
Her zaman: 1,020
