Ana içeriğe geç
Door Hinge Replacement
Neye ihtiyacın var
  1. Door Hinge Replacement, Hinge: adım 1, 2 resimden 1. Door Hinge Replacement, Hinge: adım 1, 2 resimden 2.
    • Take measurements of the door hinge using a tape measure and use the measurements to find a replacement door hinge.
  2. Door Hinge Replacement: adım 2, 2 resimden 1. Door Hinge Replacement: adım 2, 2 resimden 2.
    • Use two sturdy pieces of wood or cardboard that can keep the door in place and put them underneath the door.
    • Make sure that the door isn’t slanted or tilted to make it easier to replace the new door hinge.
  3. Door Hinge Replacement: adım 3, 2 resimden 1. Door Hinge Replacement: adım 3, 2 resimden 2.
    • Remove the three screws from the hinge that are connected to the door by using a Phillips 1 screwdriver.
    • Remove the three screws from the hinge that are connected to the door frame using a Phillips #1 screwdriver.
  4. Door Hinge Replacement: adım 4, 2 resimden 1. Door Hinge Replacement: adım 4, 2 resimden 2.
    • Repeat Step 3 with the bottom hinge on the door.
  5. Door Hinge Replacement: adım 5, 2 resimden 1. Door Hinge Replacement: adım 5, 2 resimden 2.
    • Rub sandpaper on the areas where the new hinges will be.
    • This makes sure that splinters or any wood debris from both the frame and the door will be removed.
  6. Door Hinge Replacement: adım 6, 2 resimden 1. Door Hinge Replacement: adım 6, 2 resimden 2.
    • When replacing your new door hinge, make sure that the hinge that is facing towards you can be fully closed
  7. Door Hinge Replacement: adım 7, 3 resimden 1. Door Hinge Replacement: adım 7, 3 resimden 2. Door Hinge Replacement: adım 7, 3 resimden 3.
    • Align the new door hinge with the screw holes in the frame and screw in the new door hinge in the frame.
    • Repeat this with the bottom area of the door.
  8. Door Hinge Replacement: adım 8, 3 resimden 1. Door Hinge Replacement: adım 8, 3 resimden 2. Door Hinge Replacement: adım 8, 3 resimden 3.
    • Align the new door hinge with the screw holes in the door and screw in the new door hinge.
  9. Door Hinge Replacement: adım 9, 2 resimden 1. Door Hinge Replacement: adım 9, 2 resimden 2.
    • Spray a small amount of WD-40 at the back top and bottom hinge and wipe it down with an old rag.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 813
