Ana içeriğe geç
Door Mirror Replacement
Neye ihtiyacın var
  1. Door Mirror Replacement, Door Mirror: adım 1, 1 resimden 1.
    • Use a screwdriver to remove the two brackets securing the top of the mirror.
    • The mirror will fall forward once the two top brackets are released; be sure to support the mirror as you unscrew the brackets.
    • The type of screwdriver needed will depend on your specific brackets.
  2. Door Mirror Replacement: adım 2, 1 resimden 1.
    • Lift the broken mirror off of the door.
    • Remove any cardboard or other cushioning (if any) from the door.
  3. Door Mirror Replacement: adım 3, 1 resimden 1.
    • Loosen, but don't remove, the bottom brackets to accommodate the width of the new mirror.
  4. Door Mirror Replacement: adım 4, 1 resimden 1.
    • If you have new mirror supports, then remove the old brackets entirely and replace them with the new brackets.
  5. Door Mirror Replacement: adım 5, 1 resimden 1.
    • Replace any cushioning behind the mirror.
    • While supporting the top of the mirror, set the mirror into the bottom brackets, then tighten the brackets.
  6. Door Mirror Replacement: adım 6, 1 resimden 1.
    • Replace the top brackets and tighten them to full secure the mirror.
Sonuç
Enjoy your new mirror!
Seth Wanderman
133 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 27
Her zaman: 933
