Ana içeriğe geç
Door Stop Replacement
Neye ihtiyacın var
  1. Door Stop Replacement, Door Stop: adım 1, 3 resimden 1. Door Stop Replacement, Door Stop: adım 1, 3 resimden 2. Door Stop Replacement, Door Stop: adım 1, 3 resimden 3.
    • Twist the anchor fitting of the old door stop in counter clockwise direction.
    • Remove the anchor fitting from the mount.
    • Anchor fitting: is a part of the door stop circled in red.
  2. Door Stop Replacement: adım 2, 3 resimden 1. Door Stop Replacement: adım 2, 3 resimden 2. Door Stop Replacement: adım 2, 3 resimden 3.
    • Use a drill (or a screwdriver) to remove the two screws from the mount base.
    • After you remove the mount base, use the hammer to reposition these two screws.
  3. Door Stop Replacement: adım 3, 2 resimden 1. Door Stop Replacement: adım 3, 2 resimden 2.
    • Use a screwdriver to remove the mount base out of the new anchor fitting by spinning the screwdriver counter-clockwise.
  4. Door Stop Replacement: adım 4, 3 resimden 1. Door Stop Replacement: adım 4, 3 resimden 2. Door Stop Replacement: adım 4, 3 resimden 3.
    • Using a screwdriver or a drill, attach the new mount base to the wall with the two screws.
  5. Door Stop Replacement: adım 5, 3 resimden 1. Door Stop Replacement: adım 5, 3 resimden 2. Door Stop Replacement: adım 5, 3 resimden 3.
    • Attach the anchor fitting into the mount base by rotating it clockwise.
  6. Door Stop Replacement: adım 6, 2 resimden 1. Door Stop Replacement: adım 6, 2 resimden 2.
    • Remove the old door fitting by rotating it counter-clockwise.
  7. Door Stop Replacement: adım 7, 3 resimden 1. Door Stop Replacement: adım 7, 3 resimden 2. Door Stop Replacement: adım 7, 3 resimden 3.
    • Use the drill to remove the two screws out of the threaded insert.
    • Clean the screws holes (if necessary) before putting a new screw in.
  8. Door Stop Replacement: adım 8, 3 resimden 1. Door Stop Replacement: adım 8, 3 resimden 2. Door Stop Replacement: adım 8, 3 resimden 3.
    • Insert a screwdriver into the bottom hole of the threaded insert and rotate it counter-clockwise to remove the threaded insert.
  9. Door Stop Replacement: adım 9, 2 resimden 1. Door Stop Replacement: adım 9, 2 resimden 2.
    • Place the threaded insert onto the door.
    • Using a screwdriver or a drill, attach the threaded insert to the door with two screws.
  10. Door Stop Replacement: adım 10, 3 resimden 1. Door Stop Replacement: adım 10, 3 resimden 2. Door Stop Replacement: adım 10, 3 resimden 3.
    • Assemble the rest of the door stop in the following order:
    • Spring.
    • Rectangular compartment.
    • Door stop button.
    • Outer shell.
    • Place the door stopper onto the threaded insert and and attach it by rotating it clockwise.
Sonuç
Khoa Bui
198 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 56
Her zaman: 3,759
