Ana içeriğe geç
Doorknob Privacy Pin Replacement
Neye ihtiyacın var
  1. Doorknob Privacy Pin Replacement, Doorknob Privacy Pin: adım 1, 3 resimden 1. Doorknob Privacy Pin Replacement, Doorknob Privacy Pin: adım 1, 3 resimden 2. Doorknob Privacy Pin Replacement, Doorknob Privacy Pin: adım 1, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the two screws holding the interior and exterior doorknob halves together.
  2. Doorknob Privacy Pin Replacement: adım 2, 2 resimden 1. Doorknob Privacy Pin Replacement: adım 2, 2 resimden 2.
    • Carefully pull the doorknob halves apart.
    • The spindle and the latch mechanism should now be accessible.
  3. Doorknob Privacy Pin Replacement: adım 3, 3 resimden 1. Doorknob Privacy Pin Replacement: adım 3, 3 resimden 2. Doorknob Privacy Pin Replacement: adım 3, 3 resimden 3.
    • Use the Phillips #1 screwdriver to remove the privacy pin.
    • It is a small, threaded pin that screws into a hole on the latch mechanism itself or on the interior doorknob assembly.
  4. Doorknob Privacy Pin Replacement: adım 4, 1 resimden 1.
    • Remove the old/ damaged privacy pin.
  5. Doorknob Privacy Pin Replacement: adım 5, 3 resimden 1. Doorknob Privacy Pin Replacement: adım 5, 3 resimden 2. Doorknob Privacy Pin Replacement: adım 5, 3 resimden 3.
    • Screw the new privacy pin into the corresponding hole.
    • Ensure it's securely tightened but don't overtighten, as this could strip the threads.
  6. Doorknob Privacy Pin Replacement: adım 6, 3 resimden 1. Doorknob Privacy Pin Replacement: adım 6, 3 resimden 2. Doorknob Privacy Pin Replacement: adım 6, 3 resimden 3.
    • Align the spindle with the latch mechanism, then bring the two doorknob halves back together.
    • Make sure all parts are properly seated.
  7. Doorknob Privacy Pin Replacement: adım 7, 3 resimden 1. Doorknob Privacy Pin Replacement: adım 7, 3 resimden 2. Doorknob Privacy Pin Replacement: adım 7, 3 resimden 3.
    • Securely fasten the two screws with the Phillips #1 screwdriver.
    • Snap or twist the decorative covers back into place (If applicable).
    • Test the privacy pin several times to ensure it engages and disengages smoothly.
Sonuç
Elias Moseri
145 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 51
Her zaman: 296
