Giriş
Skills you will need to be familiar with are soldering. Besides a new battery, you will also need access to a soldering kit.
Neye ihtiyacın var
The rear panel is secured to the front case and can simply be pried apart without damage.
Using wire strippers, strip the ends of the red and black wires connected to the the new battery back about a 1/8".
Twist the strands of the spliced wire together.
When the connection is hot enough melt solder on the opposite side of the wire to the iron as shown in the image. Do not melt to much solder.
Repeat this process with the other wire.
This video provides basic instructions for splicing wires using crimping and heat shrink technique.
Bir başkası bu kılavuzu tamamladı.
