Ana içeriğe geç
Dopo Double Power 7 Camera Replacement
Neye ihtiyacın var
  1. Dopo Double Power 7 Camera Replacement, Rear Panel: adım 1, 1 resimden 1.
    • The rear panel is secured to the front case and can simply be pried apart without damage.
  2. Dopo Double Power 7 Camera Replacement: adım 2, 1 resimden 1.
    • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
  3. Dopo Double Power 7 Camera Replacement: adım 3, 1 resimden 1.
    • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
  4. Dopo Double Power 7 Camera Replacement: adım 4, 1 resimden 1.
    • The rear panel should come completely off.
  5. Dopo Double Power 7 Camera Replacement, Camera: adım 5, 1 resimden 1.
    • Remove any black static tape that may be covering the motherboard.
  6. Dopo Double Power 7 Camera Replacement: adım 6, 2 resimden 1. Dopo Double Power 7 Camera Replacement: adım 6, 2 resimden 2.
    • The camera is taped in place.
    • Use the flat end of a spudger to disconnect the front-facing camera cable from its socket on the motherboard.
    • Our cable had previously been cut but yours can be disconnected by lifting up on the black section of the socket, as shown by the arrow, and pulling the cable out.
    • Simply, pull back the tape and remove the camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
mike pelosi
682 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-2, Miles Fall 2015 UMass Dartmouth, Team 1-2, Miles Fall 2015 üyesi
UMASSD-MILES-F15S1G2
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 11
Her zaman: 165
