Giriş
Purchasing a new or used display/digitizer will be necessary if yours is broken.
Neye ihtiyacın var
The rear panel is secured to the front case and can simply be pried apart without damage.
Bu adımda kullanılan alet:Tweezers$4.99
Remove the four screws holding the motherboard inplace.
Using the flat end of a spudger or tweezers, remove the three cables connected to the motherboard.
The cables can be disconnected by lifting up on the black section of the socket.
Once the lever is lifted, pull out the cable by gently tugging on it.
2 farklı kişi bu kılavuzu tamamladı.
