Ana içeriğe geç
Dopo Double Power 7 Motherboard Replacement
Neye ihtiyacın var
  1. Dopo Double Power 7 Motherboard Replacement, Rear Panel: adım 1, 1 resimden 1.
    • The rear panel is secured to the front case and can simply be pried apart without damage.
  2. Dopo Double Power 7 Motherboard Replacement: adım 2, 1 resimden 1.
    • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
  3. Dopo Double Power 7 Motherboard Replacement: adım 3, 1 resimden 1.
    • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
  4. Dopo Double Power 7 Motherboard Replacement: adım 4, 1 resimden 1.
    • The rear panel should come completely off.
  5. Dopo Double Power 7 Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Remove any static tape covering the motherboard.
  6. Dopo Double Power 7 Motherboard Replacement: adım 6, 2 resimden 1. Dopo Double Power 7 Motherboard Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using the flat end of a spudger or tweezers, remove the three cables connected to the motherboard.
    • The cables can be disconnected by lifting up on the black section of the socket, as shown by the arrow.
    • Once the lever is lifted, pull out the cable by gently tugging on it.
  7. Dopo Double Power 7 Motherboard Replacement: adım 7, 1 resimden 1.
    • Using a Phillips Head Screwdriver size 0, remove the four screws attaching the motherboard.
  8. Dopo Double Power 7 Motherboard Replacement: adım 8, 2 resimden 1. Dopo Double Power 7 Motherboard Replacement: adım 8, 2 resimden 2.
    • Using wire cutters, cut the red, black, and grays wires.
    • The motherboard can now be removed
    • Leave enough wire to be re-soldered back if possible.
Sonuç
Bir başkası bu kılavuzu tamamladı.
mike pelosi
682 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-2, Miles Fall 2015 UMass Dartmouth, Team 1-2, Miles Fall 2015 üyesi
UMASSD-MILES-F15S1G2
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 508
