Ana içeriğe geç
Draft Inducer Motor Replacement
Neye ihtiyacın var
    1. Draft Inducer Motor Replacement, Draft Inducer Motor: adım 1, 2 resimden 1. Draft Inducer Motor Replacement, Draft Inducer Motor: adım 1, 2 resimden 2.
      • Start by turning off the flow of gas to your furnace, as well as cutting power to the whole furnace by flipping the service switch to the "Off" position.
      • If your furnace doesn't have a service switch nearby, you'll need to cut power to it at the breaker box.
      FixBot'a Sor
      Yorum Ekle
    2. Draft Inducer Motor Replacement: adım 2, 2 resimden 1. Draft Inducer Motor Replacement: adım 2, 2 resimden 2.
      • Grab the handle on the front panel marked "Lift" and push up to release the panel. Place it off to the side.
      FixBot'a Sor
      Yorum Ekle
    3. Draft Inducer Motor Replacement: adım 3, 3 resimden 1. Draft Inducer Motor Replacement: adım 3, 3 resimden 2. Draft Inducer Motor Replacement: adım 3, 3 resimden 3.
      • The draft inducer is located in the upper-left area of the furnace chamber.
      • Unplug the motor's Molex connector.
      • Your specific furnace model may use a draft inducer with two small connectors on the motor itself, rather than a single Molex connector.
      FixBot'a Sor
      Yorum Ekle
    4. Draft Inducer Motor Replacement: adım 4, 2 resimden 1. Draft Inducer Motor Replacement: adım 4, 2 resimden 2.
      • Use a flathead screwdriver or a 1/4-inch socket to remove the two screws holding the shield plate to the draft inducer assembly.
      • Remove the plate and set it off to the side.
      • Be sure to keep track of all the screws and bolts!
      FixBot'a Sor
      Yorum Ekle
    5. Draft Inducer Motor Replacement: adım 5, 3 resimden 1. Draft Inducer Motor Replacement: adım 5, 3 resimden 2. Draft Inducer Motor Replacement: adım 5, 3 resimden 3.
      • Use a 1/4-inch socket to remove the three mounting bolts securing the draft inducer assembly to the furnace.
      • Support the motor and assembly from the bottom and slowly remove it from the furnace.
      FixBot'a Sor
      Yorum Ekle
    6. Draft Inducer Motor Replacement: adım 6, 2 resimden 1. Draft Inducer Motor Replacement: adım 6, 2 resimden 2.
      • Use a flathead screwdriver or a small pry tool to carefully pry off the circular clip from the cooling fan.
      • Be careful not to apply a lot of pressure on the fan itself, since it's made of plastic and will break with enough force.
      FixBot'a Sor
      Yorum Ekle
    7. Draft Inducer Motor Replacement: adım 7, 3 resimden 1. Draft Inducer Motor Replacement: adım 7, 3 resimden 2. Draft Inducer Motor Replacement: adım 7, 3 resimden 3.
      • Remove the cooling fan from the motor's driveshaft.
      • You may need to apply a decent amount of pressure and wiggle the fan in order to knock it loose.
      FixBot'a Sor
      Yorum Ekle
    8. Draft Inducer Motor Replacement: adım 8, 3 resimden 1. Draft Inducer Motor Replacement: adım 8, 3 resimden 2. Draft Inducer Motor Replacement: adım 8, 3 resimden 3.
      • Flip the assembly over and use a 1/8-inch hex key to loosen the set screw securing the blower fan to the motor's driveshaft.
      • More than likely, the fan and set screw will be rusted and seized to the driveshaft. A few sprays of penetrating oil will help loosen it up.
      FixBot'a Sor
      Yorum Ekle
    9. Draft Inducer Motor Replacement: adım 9, 3 resimden 1. Draft Inducer Motor Replacement: adım 9, 3 resimden 2. Draft Inducer Motor Replacement: adım 9, 3 resimden 3.
      • Remove the blower fan from the motor's driveshaft.
      • As with the cooling fan, you may need to apply a decent amount of pressure and wiggle the blower fan in order to remove it.
      FixBot'a Sor
      Yorum Ekle
    10. Draft Inducer Motor Replacement: adım 10, 3 resimden 1. Draft Inducer Motor Replacement: adım 10, 3 resimden 2. Draft Inducer Motor Replacement: adım 10, 3 resimden 3.
      • Flip over the assembly and use a 1/4-inch socket to remove the three bolts securing the motor bracket to the motor plate.
      • Once the bolts are removed, flip the assembly back over and remove the motor bracket.
      • Once removed, take note of the motor's ground wire, which connects to one of the bracket bolts. Be sure to reconnect it during reassembly.
      FixBot'a Sor
      Yorum Ekle
    11. Draft Inducer Motor Replacement: adım 11, 2 resimden 1. Draft Inducer Motor Replacement: adım 11, 2 resimden 2.
      • Use a 1/4-inch socket to remove the two bolts securing the motor to the motor plate.
      • Remove the motor bracket.
      FixBot'a Sor
      Yorum Ekle
    12. Draft Inducer Motor Replacement: adım 12, 1 resimden 1.
      • When installing the blower fan onto the new motor, be sure that the set screw on the blower fan lines up with the flat edge of the motor's driveshaft.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Craig Lloyd
43.067 İtibar
82 adet Kılavuz yazıldı
3Kılavuz Yorumları
Thanks for the instructions, very helpful.
Do you know the Inducer motor part number?
Selvan Lingam - Yanıt Paylaş
Good morning, I need the whole unit ( motor, fan, blower fan, ) etc. This looks like same same unit I have but I can't find a model number for this to make sure I purchase the right one for my unit. I have a carrier weathermaker 8000vs looks exactly like the one here can someone please provide some helpful information thanks.
Joshua Thomas - Yanıt Paylaş
Any one know part number for motor for inducer model 22307501
Thanks
Chod - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 90
Her zaman: 28,377
