Ana içeriğe geç
Dragon Touch M10X Camera Replacement
Neye ihtiyacın var
  1. Dragon Touch M10X Camera Replacement, Camera: adım 1, 2 resimden 1. Dragon Touch M10X Camera Replacement, Camera: adım 1, 2 resimden 2.
    • Remove the two screws from the top of the tablet as shown in the figure using a J0 philips head bit.
  2. Dragon Touch M10X Camera Replacement: adım 2, 1 resimden 1.
    • Use the large plastic opening tool to separate the back cover from the device. Wedge the sharp end of the tool into the crack and use leverage to further separate the back cover from the device.
    • Still holding pressure on the opening tool, slowly and carefully slide the tool along the gap to separate it further. You should hear slight snapping as it comes apart. Work your way around all sides until the cover is able to be removed.
  3. Dragon Touch M10X Camera Replacement: adım 3, 2 resimden 1. Dragon Touch M10X Camera Replacement: adım 3, 2 resimden 2.
    • Using your hands and the separating tool, remove the back cover from the device.
  4. Dragon Touch M10X Camera Replacement: adım 4, 1 resimden 1.
    • Using a J0 phillips head bit, remove the single 1 mm screw from the rear facing lens cover.
  5. Dragon Touch M10X Camera Replacement: adım 5, 1 resimden 1.
    • Using a J0 phillips head bit, remove the single 1mm screw from the front facing camera lens cover.
  6. Dragon Touch M10X Camera Replacement: adım 6, 1 resimden 1.
    • Using a plastic opening tool, pry the rear facing camera out of its housing.
  7. Dragon Touch M10X Camera Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using a plastic opening tool, lift up the latch that attaches the camera's ribbon cable to the device.
    • Using tweezers, pull out the ribbon cable from underneath the latch.
  8. Dragon Touch M10X Camera Replacement: adım 8, 1 resimden 1.
    • Remove the camera strip from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Joseph Rockcliffe
612 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-7, Catania Spring 2016 UMass Dartmouth, Team 4-7, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S4G7
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 507
