Ana içeriğe geç
Dragon Touch Y88X Plus Motherboard Replacement
Neye ihtiyacın var
  1. Dragon Touch Y88X Plus Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Remove the back case using a plastic opening tool or spudger.
    • Start at the corners and work your way around the perimeter of the tablet.
    • Be gentle to avoid damaging the case or any internal components.
  2. Dragon Touch Y88X Plus Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove any adhesive strips keeping wires in place.
  3. Dragon Touch Y88X Plus Motherboard Replacement: adım 3, 1 resimden 1.
    • Desolder the wires connected to the motherboard to disconnect the battery and speaker.
  4. Dragon Touch Y88X Plus Motherboard Replacement: adım 4, 2 resimden 1. Dragon Touch Y88X Plus Motherboard Replacement: adım 4, 2 resimden 2.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on the three ZIF connectors.
    • Be sure to pry up on the hinged flap, not the connector socket.
    • Use a spudger to slide the ribbon cables from the connectors.
  5. Dragon Touch Y88X Plus Motherboard Replacement: adım 5, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the edges of the motherboard.
  6. Dragon Touch Y88X Plus Motherboard Replacement: adım 6, 1 resimden 1.
    • Gently lift the motherboard from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Cody Camara
149 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-4, Petersen Fall 2023 UMass Dartmouth, Team 1-4, Petersen Fall 2023 üyesi
UMASSD-PETERSEN-F23S1G4
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 6
Her zaman: 107
