Ana içeriğe geç
Draining a Toilet Tank
  1. Draining a Toilet Tank, Tank Lid: adım 1, 3 resimden 1. Draining a Toilet Tank, Tank Lid: adım 1, 3 resimden 2. Draining a Toilet Tank, Tank Lid: adım 1, 3 resimden 3.
    • Lift the tank lid up and away from the toilet tank.
  2. Draining a Toilet Tank, Shutting off the Water Supply to a Toilet: adım 2, 2 resimden 1. Draining a Toilet Tank, Shutting off the Water Supply to a Toilet: adım 2, 2 resimden 2.
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Draining a Toilet Tank, Draining a Toilet Tank: adım 3, 2 resimden 1. Draining a Toilet Tank, Draining a Toilet Tank: adım 3, 2 resimden 2.
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
Sonuç
Most toilets retain a small amount of water in the tank after draining. To remove any excess water from the bottom of your toilet tank, use our guide for Sponge Drying a Toilet Tank.
Bir başkası bu kılavuzu tamamladı.
Ron Davis
32.949 İtibar
13 adet Kılavuz yazıldı
2Kılavuz Yorumları
I have a cracking in my toilet tank going almost the length of the tank and below water line resulting in a leak. In your experience is a sealant a good option or in reality would the tank need to be replaced in time ?
Thanks
K EVANS - Yanıt
It would make more sense to replace the tank, than seal any crack which would only reappear after time anyway.
John Turner -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 41
Son 30 gün: 176
Her zaman: 35,615
