Ana içeriğe geç
Dremel 4000 Power Cord Replacement
Neye ihtiyacın var
  1. Dremel 4000 Power Cord Replacement, Back Case: adım 1, 2 resimden 1. Dremel 4000 Power Cord Replacement, Back Case: adım 1, 2 resimden 2.
    • Start by removing the housing cap by unscrewing it.
    • Next, unscrew the now exposed collet nut while holding down the shaft lock button.
    • To remove the collet nut, you may need to use the small open-end wrench provided with the Dremel.
  2. Dremel 4000 Power Cord Replacement: adım 2, 1 resimden 1.
    • Using your hands, carefully remove hanger from casing.
  3. Dremel 4000 Power Cord Replacement: adım 3, 2 resimden 1. Dremel 4000 Power Cord Replacement: adım 3, 2 resimden 2.
    • Remove the brush caps (one on each side) by using a flathead screwdriver bit.
    • The brush caps are spring loaded.
  4. Dremel 4000 Power Cord Replacement: adım 4, 1 resimden 1.
    • Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
  5. Dremel 4000 Power Cord Replacement: adım 5, 1 resimden 1.
    • Use a plastic opening tool to gently wedge apart the hard plastic threads.
  6. Dremel 4000 Power Cord Replacement: adım 6, 1 resimden 1.
    • Use your hands to carefully remove the back casing so that none of the components fall out.
  7. Dremel 4000 Power Cord Replacement, Power Cord: adım 7, 2 resimden 1. Dremel 4000 Power Cord Replacement, Power Cord: adım 7, 2 resimden 2.
    • To clear access to the electrical assembly, remove the variable speed dial cap and blue power lever, and set them aside.
  8. Dremel 4000 Power Cord Replacement: adım 8, 1 resimden 1.
    • Using your fingers, carefully pull the circuit board from the casing. This will make it easier to remove the power cord.
  9. Dremel 4000 Power Cord Replacement: adım 9, 1 resimden 1.
    • Each wire is fed through a small opening on the circuit board and held with a flat head screw.
    • Loosen the screw just enough to remove the wire by gently pulling it with your hand.
  10. Dremel 4000 Power Cord Replacement: adım 10, 1 resimden 1.
    • Carefully remove both wires from circuit board with your hands.
    • Take careful note of which side has the black wire and which has the white wire.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
John Cobb
1.689 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-4, Remmell Spring 2016 USF Tampa, Team 15-4, Remmell Spring 2016 üyesi
USFT-REMMELL-S16S15G4
4 Üyeler
13 adet Kılavuz yazıldı
Bir Yorum
Super handy guide after my guide dog decided to chew through the cable!
Geoff Palmer - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 14
Son 30 gün: 39
Her zaman: 5,673
