Ana içeriğe geç
Dremel 4000 Shaft Lock Pin Replacement
Neye ihtiyacın var
  1. Dremel 4000 Shaft Lock Pin Replacement, Back Case: adım 1, 2 resimden 1. Dremel 4000 Shaft Lock Pin Replacement, Back Case: adım 1, 2 resimden 2.
    • Start by removing the housing cap by unscrewing it.
    • Next, unscrew the now exposed collet nut while holding down the shaft lock button.
    • To remove the collet nut, you may need to use the small open-end wrench provided with the Dremel.
    FixBot'a Sor
    Yorum Ekle
  2. Dremel 4000 Shaft Lock Pin Replacement: adım 2, 1 resimden 1.
    • Using your hands, carefully remove hanger from casing.
    FixBot'a Sor
    Yorum Ekle
  3. Dremel 4000 Shaft Lock Pin Replacement: adım 3, 2 resimden 1. Dremel 4000 Shaft Lock Pin Replacement: adım 3, 2 resimden 2.
    • Remove the brush caps (one on each side) by using a flathead screwdriver bit.
    • The brush caps are spring loaded.
    FixBot'a Sor
    Yorum Ekle
  4. Dremel 4000 Shaft Lock Pin Replacement: adım 4, 1 resimden 1.
    • Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
    FixBot'a Sor
    Yorum Ekle
  5. Dremel 4000 Shaft Lock Pin Replacement: adım 5, 1 resimden 1.
    • Use a plastic opening tool to gently wedge apart the hard plastic threads.
    FixBot'a Sor
    Yorum Ekle
  6. Dremel 4000 Shaft Lock Pin Replacement: adım 6, 1 resimden 1.
    • Use your hands to carefully remove the back casing so that none of the components fall out.
    FixBot'a Sor
    Yorum Ekle
  7. Dremel 4000 Shaft Lock Pin Replacement, Shaft Lock Pin: adım 7, 1 resimden 1.
    • If the shaft lock pin is not engaging the rotary gear, or if the spring is missing or damaged, it will need to be replaced.
    • Remove the damaged shaft lock pin and spring by hand.
    • Place new shaft lock pin so that the spring functions and the lock engages the rotary gear.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
John Cobb
1.842 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-4, Remmell Spring 2016 USF Tampa, Team 15-4, Remmell Spring 2016 üyesi
USFT-REMMELL-S16S15G4
4 Üyeler
17 adet Kılavuz yazıldı
3Kılavuz Yorumları
These instructions are idiotic! I want to replace the shaft lock pin because it is not WORKING. Step 1 instructs me to use the shaft lock pin to remove the exposed collet nut. The reason I am changing the shaft lock pin is because it won’t hold the shaft for loosening the collet nut. DUH!
mitchthane - Yanıt Paylaş
three years later and I came to the same conclusion: DUH
Randy Martin - Yanıt Paylaş
Four years later and I came to the same conclusion: DUH
Ben simon - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 27
Son 30 gün: 115
Her zaman: 16,227
