Ana içeriğe geç
Dremel 4000 Shaft Lock Pin Replacement
Neye ihtiyacın var
  1. Dremel 4000 Shaft Lock Pin Replacement, Back Case: adım 1, 2 resimden 1. Dremel 4000 Shaft Lock Pin Replacement, Back Case: adım 1, 2 resimden 2.
    • Start by removing the housing cap by unscrewing it.
    • Next, unscrew the now exposed collet nut while holding down the shaft lock button.
    • To remove the collet nut, you may need to use the small open-end wrench provided with the Dremel.
    Is this a joke??? Wanna maybe possibly tell US WHAT A COLLET NUT LOOKS LIKE?? I mean it's obviously very exposed (not exposed one bit. My Dremel 4000 looks exactly like it did before. No Collet nut suddenly stood out) and not all of us have advanced degrees in Dremel parts
    Jeff Wagner - Yanıt
    Dam Jeff. I am not sure if you are being sarcastic or not, but maybe you should go lie down for while.
    itguyfla - Yanıt
  2. Dremel 4000 Shaft Lock Pin Replacement: adım 2, 1 resimden 1.
    • Using your hands, carefully remove hanger from casing.
    Mine seems to have solid caps without the slot. How are this type removed?
    claire roche - Yanıt
    This is getting worse. Maybe skipping the Collet Nut part threw me off - as there is no hanger. This description is PATHETIC!!!
    Jeff Wagner - Yanıt
    I love how these pictures show you NOTHING related to what this guy is talking about
    Jeff Wagner - Yanıt
    Wow, you guys are really amazing. Are you actually working on a Dremel 4000? Mine looks exactly like the pics. It has a hangar on it, as well as a collet nut.
    itguyfla - Yanıt
  3. Dremel 4000 Shaft Lock Pin Replacement: adım 3, 2 resimden 1. Dremel 4000 Shaft Lock Pin Replacement: adım 3, 2 resimden 2.
    • Remove the brush caps (one on each side) by using a flathead screwdriver bit.
    • The brush caps are spring loaded.
    I have found that the brushes are the most likely failure point on the Dremel tool. I haven’t purchased a new one in many years but they used to come with a spare set.
    In general commutator brushes are made of a soft high carbon compound, usually found with new springs attached. The brushes can be carefully reshaped using files, sandpaper and a razor knife to fit the recesses of the tool.
    Use the original to get necessary dimensions, a dial caliper is very helpful here to duplicate channels and recesses as well as determining how long the brushes should be. Should you need to shorten the brush a new concave can be established using a pencil or dowel wrapped in sandpaper being sure to match the concave to the channels so it matches the armature. It is preferable the curve be wider than the armature so edges don’t catch, it will naturally wear into a perfect curve. Blow off before installing.
    Once the tool is reassembled turn on and off several times then run for a while varying the speed.
    George McNew - Yanıt
  4. Dremel 4000 Shaft Lock Pin Replacement: adım 4, 1 resimden 1.
    • Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
  5. Dremel 4000 Shaft Lock Pin Replacement: adım 5, 1 resimden 1.
    • Use a plastic opening tool to gently wedge apart the hard plastic threads.
  6. Dremel 4000 Shaft Lock Pin Replacement: adım 6, 1 resimden 1.
    • Use your hands to carefully remove the back casing so that none of the components fall out.
  7. Dremel 4000 Shaft Lock Pin Replacement, Shaft Lock Pin: adım 7, 1 resimden 1.
    • If the shaft lock pin is not engaging the rotary gear, or if the spring is missing or damaged, it will need to be replaced.
    • Remove the damaged shaft lock pin and spring by hand.
    • Place new shaft lock pin so that the spring functions and the lock engages the rotary gear.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
John Cobb
1.689 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-4, Remmell Spring 2016 USF Tampa, Team 15-4, Remmell Spring 2016 üyesi
USFT-REMMELL-S16S15G4
4 Üyeler
13 adet Kılavuz yazıldı
2 Yorum
These instructions are idiotic! I want to replace the shaft lock pin because it is not WORKING. Step 1 instructs me to use the shaft lock pin to remove the exposed collet nut. The reason I am changing the shaft lock pin is because it won’t hold the shaft for loosening the collet nut. DUH!
mitchthane - Yanıt
three years later and I came to the same conclusion: DUH
Randy Martin -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 19
Son 30 gün: 143
Her zaman: 11,957
