Ana içeriğe geç
Dremel 7300 MiniMite Cordless Collet Replacement
Neye ihtiyacın var
    1. Dremel 7300 MiniMite Cordless Collet Replacement, Collet: adım 1, 3 resimden 1. Dremel 7300 MiniMite Cordless Collet Replacement, Collet: adım 1, 3 resimden 2. Dremel 7300 MiniMite Cordless Collet Replacement, Collet: adım 1, 3 resimden 3.
      • The device comes with a small black wrench to tighten the collet nut, during reassembly or changing the bits.
      • Press the blue button and hold it down.
      • Unscrew the collet nut, with your fingers (as if you were going to change the bit).
      • Continue until the collet nut comes completely off of the Dremel.
      FixBot'a Sor
      Yorum Ekle
    2. Dremel 7300 MiniMite Cordless Collet Replacement: adım 2, 3 resimden 1. Dremel 7300 MiniMite Cordless Collet Replacement: adım 2, 3 resimden 2. Dremel 7300 MiniMite Cordless Collet Replacement: adım 2, 3 resimden 3.
      • Once the collet nut is off, you can remove the collet. It is the silver part that grips the bit when the collet nut tightens on it.
      • The collet itself may be in the shaft, or come off with the nut.
      FixBot'a Sor
      Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Kat
864 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-4, Sullivan Spring 2016 USF Tampa, Team 3-4, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S3G4
4 Üyeler
4 adet Kılavuz yazıldı
2Kılavuz Yorumları
Too anyone having trouble unscrewing the collet, you may want to clamp vice grips on if its stuck tight. Worked for me.
Will - Yanıt Paylaş
I easily removed the bit by holding the blue button and using the black wrench to loosen it and then I remove the silver piece that holds the bit then when I tried to use another one of the attachments it seems like it’s too large to fit in there I haven’t been able to use any of the other attachments like polishing and the finer little grinders
Kate Denkers - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 30
Her zaman: 33,151
