Giriş
If the motor burns up or the power switch breaks, you are going to need a whole new motor and shaft for the device, as they come as one piece. This guide will show how to dissemble and remove the motor-shaft assembly.
Neye ihtiyacın var
Pull back on the release tabs to disconnect the battery pack from the housing.
Remove the two screws from the back of the device with the TR10 Torx Security screwdriver.
3 farklı kişi bu kılavuzu tamamladı.
