Ana içeriğe geç
Dremel 8200 Disassembly
Neye ihtiyacın var
  1. Dremel 8200 Disassembly, Dremel 8200 Disassembly: adım 1, 2 resimden 1. Dremel 8200 Disassembly, Dremel 8200 Disassembly: adım 1, 2 resimden 2.
    • Take off the screw cap at the top
  2. Dremel 8200 Disassembly: adım 2, 2 resimden 1. Dremel 8200 Disassembly: adım 2, 2 resimden 2.
    • Take out the battery
    • Remove oblong belt clip
  3. Dremel 8200 Disassembly: adım 4, 1 resimden 1.
    • Unscrew screws
    • Take back u clip out carefully
    • Be very careful to not injure yourself
  4. Dremel 8200 Disassembly: adım 6, 2 resimden 1. Dremel 8200 Disassembly: adım 6, 2 resimden 2.
    • The casing should just open right up and be easily accessible
  5. Dremel 8200 Disassembly: adım 7, 1 resimden 1.
    • You can remove the buttons except for the sliding one that adjusts the speed
  6. Dremel 8200 Disassembly: adım 8, 2 resimden 1. Dremel 8200 Disassembly: adım 8, 2 resimden 2.
    • You can take the motor out first and it will be a little hard to do so
    • Work your way down and take out each successive circuit board
    • The last thing to be out should be the sliding speed adjustment and the button for that should fall right out
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
mitchellbarnhart
86 İtibar
1 Kılavuz yazıldı
2 Yorum
It will be handy to have either a can of compressed air or an air directional nozzle on your compressor. Be careful of the circuits and small parts that can blow away. You'll be amazed how even with a maintenance schedule, how much dirt will be on the motor fins
m. D. w. - Yanıt
How do you replace just the bearing in this assembly?
Andre Da Silva - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 45
Her zaman: 3,529
