Ana içeriğe geç
Dremel 8220 Gear Lock Button Replacement
Neye ihtiyacın var
  1. Dremel 8220 Gear Lock Button Replacement, Gear Lock Button: adım 1, 1 resimden 1.
    • Locate the battery at the back of your Dremel. Firmly grasp the battery on both sides and pull. It should easily come out of the battery well.
    FixBot'a Sor
    Yorum Ekle
  2. Dremel 8220 Gear Lock Button Replacement: adım 2, 1 resimden 1.
    • Remove the ring located around the speed selector switch by pulling apart on either side. This should require very minimal force.
    FixBot'a Sor
    Yorum Ekle
  3. Dremel 8220 Gear Lock Button Replacement: adım 3, 1 resimden 1.
    • Remove the collar wrench by pushing the gear lock button. Continue to hold this button as you rotate the wrench counter-clockwise until it is removed.
    FixBot'a Sor
    Yorum Ekle
  4. Dremel 8220 Gear Lock Button Replacement: adım 4, 1 resimden 1.
    • Remove the metal clasp from the battery well. This piece helps hold the plastic shell of the device together. Pry it out by gently applying some force with a screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Dremel 8220 Gear Lock Button Replacement: adım 5, 3 resimden 1. Dremel 8220 Gear Lock Button Replacement: adım 5, 3 resimden 2. Dremel 8220 Gear Lock Button Replacement: adım 5, 3 resimden 3.
    • Remove the 5 torx screws using a t9 screwdriver head.
    • Now pull apart the plastic shell of the device. If you are not able to, review the previous steps as you may have missed one.
    FixBot'a Sor
    Yorum Ekle
  6. Dremel 8220 Gear Lock Button Replacement: adım 6, 1 resimden 1.
    • Remove the faulty gear lock button. It should come out of the device easily with no force needed.
    FixBot'a Sor
    Yorum Ekle
Sonuç
connor anisko
312 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-8, Isaacson Spring 2016 UMass Dartmouth, Team 2-8, Isaacson Spring 2016 üyesi
UMASSD-ISAACSON-S16S2G8
3 Üyeler
5 adet Kılavuz yazıldı
3Kılavuz Yorumları
I’m assuming the issue I have is a faulty gear-lock button (that, or the locking gear that it restricts when depressed). If so, did you find a replacement button from the manufacturer? In my experience, they rarely offer repair parts themselves.
Robert - Yanıt Paylaş
I also don’t understand why there was a flag claiming that this should be broken into separate guides. People aren’t THAT stupid, I hope.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 44
Her zaman: 1,365
