Ana içeriğe geç
Dremel 8220 Power Switch Replacement
Neye ihtiyacın var
    1. Dremel 8220 Power Switch Replacement, Power Switch: adım 1, 1 resimden 1.
      • Locate the battery at the back of your Dremel. Firmly grasp the battery on both sides and pull. It should easily come out of the battery well.
      FixBot'a Sor
      Yorum Ekle
    2. Dremel 8220 Power Switch Replacement: adım 2, 1 resimden 1.
      • Remove the ring located around the speed selector switch by pulling apart on either side. This should require very minimal force.
      FixBot'a Sor
      Yorum Ekle
    3. Dremel 8220 Power Switch Replacement: adım 3, 1 resimden 1.
      • Remove the collar wrench by pushing the gear lock button. Continue to hold this button as you rotate the wrench counter-clockwise until it is removed.
      FixBot'a Sor
      Yorum Ekle
    4. Dremel 8220 Power Switch Replacement: adım 4, 1 resimden 1.
      • Remove the metal clasp from the battery well. This piece helps hold the plastic shell of the device together. Pry it out by gently applying some force with a screwdriver.
      FixBot'a Sor
      Yorum Ekle
    5. Dremel 8220 Power Switch Replacement: adım 5, 3 resimden 1. Dremel 8220 Power Switch Replacement: adım 5, 3 resimden 2. Dremel 8220 Power Switch Replacement: adım 5, 3 resimden 3.
      • Remove five T9 Torx screws from the side of the tool.
      • Now pull apart the plastic shell of the device. If you are not able to, review the previous steps as you may have missed one.
      FixBot'a Sor
      Yorum Ekle
    6. Dremel 8220 Power Switch Replacement: adım 6, 1 resimden 1.
      • Remove the faulty power switch. It should come out of the device without using any force.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Shailing Santiago
406 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-8, Isaacson Spring 2016 UMass Dartmouth, Team 2-8, Isaacson Spring 2016 üyesi
UMASSD-ISAACSON-S16S2G8
3 Üyeler
5 adet Kılavuz yazıldı
1Rehber Yorum
Awesome!! Thanks!
christooher t - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 29
Her zaman: 2,627
