Ana içeriğe geç
Dremel 8220 Speed Selector Switch Replacement
Neye ihtiyacın var
  1. Dremel 8220 Speed Selector Switch Replacement, Speed selector switch: adım 1, 1 resimden 1.
    • Locate the battery at the back of your Dremel. Firmly grasp the battery on both sides and pull. It should easily come out of the battery well.
    FixBot'a Sor
    Yorum Ekle
  2. Dremel 8220 Speed Selector Switch Replacement: adım 2, 1 resimden 1.
    • Remove the ring located around the speed selector switch by pulling apart on either side. This should require very minimal force.
    FixBot'a Sor
    Yorum Ekle
  3. Dremel 8220 Speed Selector Switch Replacement: adım 3, 1 resimden 1.
    • Remove the collar wrench by pushing the gear lock button. Continue to hold this button as you rotate the wrench counter-clockwise until it is removed.
    FixBot'a Sor
    Yorum Ekle
  4. Dremel 8220 Speed Selector Switch Replacement: adım 4, 1 resimden 1.
    • Remove the metal clasp from the battery well. This piece helps hold the plastic shell of the device together. Pry it out by gently applying some force with a screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Dremel 8220 Speed Selector Switch Replacement: adım 5, 3 resimden 1. Dremel 8220 Speed Selector Switch Replacement: adım 5, 3 resimden 2. Dremel 8220 Speed Selector Switch Replacement: adım 5, 3 resimden 3.
    • Remove the 5 torx screws using a t9 screwdriver head.
    • Now pull apart the plastic shell of the device. If you are not able to, review the previous steps as you may have missed one.
    FixBot'a Sor
    Yorum Ekle
  6. Dremel 8220 Speed Selector Switch Replacement: adım 6, 1 resimden 1.
    • The speed selector switch is now easily accessible. Grab the switch and lift it out of the circuit board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Meeley Bien Aime
185 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-8, Isaacson Spring 2016 UMass Dartmouth, Team 2-8, Isaacson Spring 2016 üyesi
UMASSD-ISAACSON-S16S2G8
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 25
Her zaman: 1,320
