Ana içeriğe geç
Dremel MultiPro 395 Armature Replacement
Neye ihtiyacın var
  1. Dremel MultiPro 395 Armature Replacement, Remove the Blue caps: adım 1, 2 resimden 1. Dremel MultiPro 395 Armature Replacement, Remove the Blue caps: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Satın Al
    • Remove the blue caps located on either side of the MultiPro, using a 3 mm flathead screwdriver.
  2. Dremel MultiPro 395 Armature Replacement, Remove the carbon brushes: adım 2, 2 resimden 1. Dremel MultiPro 395 Armature Replacement, Remove the carbon brushes: adım 2, 2 resimden 2.
    • Carefully remove the carbon brushes attached at the end of the springs by gently pulling on the springs using your hands.
  3. Dremel MultiPro 395 Armature Replacement, Removing the Hanger: adım 3, 2 resimden 1. Dremel MultiPro 395 Armature Replacement, Removing the Hanger: adım 3, 2 resimden 2.
    • Pull one side of the hanger up and then pull away from the Multipro until the other side can be pulled out.
  4. Dremel MultiPro 395 Armature Replacement, Remove the screws in the casing: adım 4, 3 resimden 1. Dremel MultiPro 395 Armature Replacement, Remove the screws in the casing: adım 4, 3 resimden 2. Dremel MultiPro 395 Armature Replacement, Remove the screws in the casing: adım 4, 3 resimden 3.
    • Remove the 4 screws located on the bottom of the Multipro with a T15 screwdriver.
  5. Dremel MultiPro 395 Armature Replacement, Removing the chuck cap: adım 5, 3 resimden 1. Dremel MultiPro 395 Armature Replacement, Removing the chuck cap: adım 5, 3 resimden 2. Dremel MultiPro 395 Armature Replacement, Removing the chuck cap: adım 5, 3 resimden 3.
    • Hold down the collet lock, remove the chuck cap from the top of the Multipro by screwing counterclockwise.
  6. Dremel MultiPro 395 Armature Replacement, Removing the black housing cap: adım 6, 3 resimden 1. Dremel MultiPro 395 Armature Replacement, Removing the black housing cap: adım 6, 3 resimden 2. Dremel MultiPro 395 Armature Replacement, Removing the black housing cap: adım 6, 3 resimden 3.
    • Remove the black housing cap from the Multipro located directly below the chuck cap.
  7. Dremel MultiPro 395 Armature Replacement, Removing the outer casing: adım 7, 3 resimden 1. Dremel MultiPro 395 Armature Replacement, Removing the outer casing: adım 7, 3 resimden 2. Dremel MultiPro 395 Armature Replacement, Removing the outer casing: adım 7, 3 resimden 3.
    • Pull the bottom side of the casing up to remove it.
  8. Dremel MultiPro 395 Armature Replacement, Removing the motorshaft: adım 8, 3 resimden 1. Dremel MultiPro 395 Armature Replacement, Removing the motorshaft: adım 8, 3 resimden 2. Dremel MultiPro 395 Armature Replacement, Removing the motorshaft: adım 8, 3 resimden 3.
    • Gently lift the motor shaft out of the Multipro.
  9. Dremel MultiPro 395 Armature Replacement, Removing the rubber ring: adım 9, 3 resimden 1. Dremel MultiPro 395 Armature Replacement, Removing the rubber ring: adım 9, 3 resimden 2. Dremel MultiPro 395 Armature Replacement, Removing the rubber ring: adım 9, 3 resimden 3.
    • Remove the rubber ring from the bottom of the armature.
  10. Dremel MultiPro 395 Armature Replacement, Removing the on/off switch: adım 10, 3 resimden 1. Dremel MultiPro 395 Armature Replacement, Removing the on/off switch: adım 10, 3 resimden 2. Dremel MultiPro 395 Armature Replacement, Removing the on/off switch: adım 10, 3 resimden 3.
    • Pull the on/off switch off of the 120V field, paying careful attention to the prongs on the on/off switch.
    • For reassembly, make sure the prongs are touching the metal connectors on the bottom of the 120V field
  11. Dremel MultiPro 395 Armature Replacement, Removing the armature: adım 11, 3 resimden 1. Dremel MultiPro 395 Armature Replacement, Removing the armature: adım 11, 3 resimden 2. Dremel MultiPro 395 Armature Replacement, Removing the armature: adım 11, 3 resimden 3.
    • Carefully slide the armature out of the 120V field.
  12. Dremel MultiPro 395 Armature Replacement, Inserting new armature: adım 12, 3 resimden 1. Dremel MultiPro 395 Armature Replacement, Inserting new armature: adım 12, 3 resimden 2. Dremel MultiPro 395 Armature Replacement, Inserting new armature: adım 12, 3 resimden 3.
    • Carefully slide the new armature back into the 120V field.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
4 Yorum
This part does not seem to be my problem the only thing I have left on the shaft is the copper coil the fan and whatever the part above the fan it spins freely around and it seems to be set on a device that allows it to tilt. I am struggling with this, please point me in the right direction of the removal of the copper core coil.... There has got to be an easier way to remove this.
Johnny Reb - Yanıt
The article does not mention why an armature needs to be replaced. So why is it necessary to replace an armature? If there is no obviously visible problem, what could be wrong with it?
mycle85719 - Yanıt
very good article, congratulations for the content
<a href="https://comodemorarpragozar.com/"> comodemorarpragozar </a>
tiagoraro - Yanıt
My problem is with the Dremel is making a grinding noise. May be bearings? Good article. Love I fixit.
philight - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 46
Her zaman: 8,002
