Ana içeriğe geç
Dress Shirt Button Replacement
Neye ihtiyacın var
  1. Dress Shirt Button Replacement, Button: adım 1, 2 resimden 1. Dress Shirt Button Replacement, Button: adım 1, 2 resimden 2.
    • Measure out two feet of thread and cut it.
  2. Dress Shirt Button Replacement: adım 2, 3 resimden 1. Dress Shirt Button Replacement: adım 2, 3 resimden 2. Dress Shirt Button Replacement: adım 2, 3 resimden 3.
    • The needle is sharp. Be careful when working.
    • Put the thread through the eye of the needle.
    • Pull the thread through so that both ends are even.
    • Tie both strings into a knot, closing the loop
  3. Dress Shirt Button Replacement: adım 3, 2 resimden 1. Dress Shirt Button Replacement: adım 3, 2 resimden 2.
    • Begin sewing by putting the needle through the back of the fabric, out to the front, and through a hole in the button.
    • Make sure the button is facing the correct direction.
  4. Dress Shirt Button Replacement: adım 4, 3 resimden 1. Dress Shirt Button Replacement: adım 4, 3 resimden 2. Dress Shirt Button Replacement: adım 4, 3 resimden 3.
    • Put the needle through the hole diagonal and feed through to the back of the shirt
    • Repeat this process for the other diagonal.
    • Repeat the process of sewing through the diagonals multiple times.
  5. Dress Shirt Button Replacement: adım 5, 1 resimden 1.
    • When there is about 4 inches of thread yet, push the thread so that it is on the back side of the fabric.
    • Then push the needle back through making sure to not go through the button again.
  6. Dress Shirt Button Replacement: adım 6, 3 resimden 1. Dress Shirt Button Replacement: adım 6, 3 resimden 2. Dress Shirt Button Replacement: adım 6, 3 resimden 3.
    • Wrap the thread around the button 4-6 times.
  7. Dress Shirt Button Replacement: adım 7, 3 resimden 1. Dress Shirt Button Replacement: adım 7, 3 resimden 2. Dress Shirt Button Replacement: adım 7, 3 resimden 3.
    • Push the thread back through to the back side of the fabric.
    • Tie the knot off and cut.
Sonuç
Your shirt is now ready to be worn again.
Bir başkası bu kılavuzu tamamladı.
Jonathan Wong
198 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 28-4, Green Spring 2015 Cal Poly, Team 28-4, Green Spring 2015 üyesi
CPSU-GREEN-S15S28G4
6 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 27
Her zaman: 3,712
