Ana içeriğe geç
Drill Master Heat Gun Fan Replacement
Neye ihtiyacın var
  1. Drill Master Heat Gun Fan Replacement, Fan: adım 1, 1 resimden 1.
    • Be sure the heat gun is unplugged before starting this process.
    • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
    • You will need a screwdriver extension.
    FixBot'a Sor
    Yorum Ekle
  2. Drill Master Heat Gun Fan Replacement: adım 2, 1 resimden 1.
    • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
    • Don't try to open the casing just yet.
    FixBot'a Sor
    Yorum Ekle
  3. Drill Master Heat Gun Fan Replacement: adım 3, 3 resimden 1. Drill Master Heat Gun Fan Replacement: adım 3, 3 resimden 2. Drill Master Heat Gun Fan Replacement: adım 3, 3 resimden 3.
    • Remove the barrel casing on either end by twisting and pulling each side off.
    FixBot'a Sor
    Yorum Ekle
  4. Drill Master Heat Gun Fan Replacement: adım 4, 1 resimden 1.
    • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
    FixBot'a Sor
    Yorum Ekle
  5. Drill Master Heat Gun Fan Replacement: adım 5, 1 resimden 1.
    • Remove the metal casing and fan cover from the fan unit.
    FixBot'a Sor
    Yorum Ekle
  6. Drill Master Heat Gun Fan Replacement: adım 6, 1 resimden 1.
    • Bend the metal prongs backward that connect the fan motor to the plastic cap.
    • Bending the brackets too far back can cause the brackets to break.
    FixBot'a Sor
    Yorum Ekle
  7. Drill Master Heat Gun Fan Replacement: adım 7, 1 resimden 1.
    • Remove the plastic cap from the motor,
    • This will allow you to work only with the motor and fan.
    FixBot'a Sor
    Yorum Ekle
  8. Drill Master Heat Gun Fan Replacement: adım 8, 1 resimden 1.
    • Remove the fan by pulling it from the motor rod and replace.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 76
Her zaman: 3,948
