Ana içeriğe geç
Drill Master Heat Gun Power Cord Replacement
Neye ihtiyacın var
  1. Drill Master Heat Gun Power Cord Replacement, Power Cord: adım 1, 1 resimden 1.
    • Be sure the heat gun is unplugged before starting this process.
    • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
    • You will need a screwdriver extension.
  2. Drill Master Heat Gun Power Cord Replacement: adım 2, 1 resimden 1.
    • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
    • Don't try to open the casing just yet.
  3. Drill Master Heat Gun Power Cord Replacement: adım 3, 3 resimden 1. Drill Master Heat Gun Power Cord Replacement: adım 3, 3 resimden 2. Drill Master Heat Gun Power Cord Replacement: adım 3, 3 resimden 3.
    • Remove the barrel casing on either end by twisting and pulling each side off.
  4. Drill Master Heat Gun Power Cord Replacement: adım 4, 1 resimden 1.
    • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
  5. Drill Master Heat Gun Power Cord Replacement: adım 5, 1 resimden 1.
    • Loosen four screws on the wire connector using the flathead 2.5 screwdriver.
    • Screws do not come out of connector.
  6. Drill Master Heat Gun Power Cord Replacement: adım 6, 1 resimden 1.
    • Disconnect the power cord wiring from the wire connector.
  7. Drill Master Heat Gun Power Cord Replacement: adım 7, 1 resimden 1.
    • Remove the two 12mm screws from the base of power cord using the PH#0 screwdriver.
  8. Drill Master Heat Gun Power Cord Replacement: adım 8, 1 resimden 1.
    • Remove the power cord from the heat gun.
Sonuç
Mikayla Kim
523 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 665
