Ana içeriğe geç
Drobo FS DRDS2-A Power Switch Replacement
Neye ihtiyacın var
  1. Drobo FS DRDS2-A Power Switch Replacement, Case: adım 1, 1 resimden 1.
    • To start getting the case off remove the front panel so it's out of the way.
  2. Drobo FS DRDS2-A Power Switch Replacement: adım 2, 2 resimden 1. Drobo FS DRDS2-A Power Switch Replacement: adım 2, 2 resimden 2.
    • Next remove the screws from the feet of the case with a phillips head screwdriver.
  3. Drobo FS DRDS2-A Power Switch Replacement: adım 3, 1 resimden 1.
    • To remove the case, place the Drobo on its back and slide the case off.
  4. Drobo FS DRDS2-A Power Switch Replacement, Power Switch: adım 4, 3 resimden 1. Drobo FS DRDS2-A Power Switch Replacement, Power Switch: adım 4, 3 resimden 2. Drobo FS DRDS2-A Power Switch Replacement, Power Switch: adım 4, 3 resimden 3.
    • Press tabs to release back cover and lift off
  5. Drobo FS DRDS2-A Power Switch Replacement: adım 5, 2 resimden 1. Drobo FS DRDS2-A Power Switch Replacement: adım 5, 2 resimden 2.
    • Push tabs in and carefully pull out the front facer and drive shelves
  6. Drobo FS DRDS2-A Power Switch Replacement: adım 6, 2 resimden 1. Drobo FS DRDS2-A Power Switch Replacement: adım 6, 2 resimden 2.
    • Unscrew the back face by removing the screw on the back sides, then slide top face apart from the others
    • If you have a Drobo 5N2, you may also need to remove the 3 screws on each side.
  7. Drobo FS DRDS2-A Power Switch Replacement: adım 7, 2 resimden 1. Drobo FS DRDS2-A Power Switch Replacement: adım 7, 2 resimden 2.
    • Carefully unplug the Power Switch and Fan wires.
  8. Drobo FS DRDS2-A Power Switch Replacement: adım 8, 1 resimden 1.
    • Press tabs on Power Switch to release the Power Switch and Push out.
    • A Spudger like object is helpful for pushing in the tabs if the fan is not removed also
  9. Drobo FS DRDS2-A Power Switch Replacement: adım 9, 2 resimden 1. Drobo FS DRDS2-A Power Switch Replacement: adım 9, 2 resimden 2.
    • Finally pull the old switch out and pop the new one in.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Rye Cassan
155 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-4, Banghart Winter 2017 Cal Poly, Team 10-4, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S10G4
3 Üyeler
5 adet Kılavuz yazıldı
4 Yorum
Hello,
great info I found here, but where do I buy a replacement button for my Drobo in Europe?
Kind regards and thank you in advance,
Heinrich
Heinrich Voelkel - Yanıt
Hi, where do I find a replacement power switch for my Drobo 5N? BTW, thanks for the great tutorial!
Stephen R Parrott - Yanıt
I took my Drobo apart and the printed numbers on the switch are R13-112. I ordered these on Amazon:
https://www.amazon.com/Twidec-Rocker-Tog...
I put it in, crossed my fingers, and BAM, worked like a charm. Hope that helps all the future DIY’ers.
tdubs - Yanıt
Good article - thanks. Discovered my Drobo 5N (cir 2014) has a 3-wire spring-loaded switch with 2V LED (green) (wires: Red - White - Blue) Press once to turn on; Press and hold to manually turn off. Can simple R13-112 SPST switch be substituted?
John W - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 36
Her zaman: 2,105
