Ana içeriğe geç
Giriş
This guide show how to replace the screen of the Motorola Droid MAXX 2 smartphone.
Parçalar
Hiçbir parça belirtilmedi.
  1. Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
    • Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
  2. Pull the sim card tray up out of the phone
    • Pull the sim card tray up out of the phone
  3. Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover. Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
    • Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
  4. Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
    • Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
  5. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  6. Pull the mid-frame off of the phone.
    • Pull the mid-frame off of the phone.
    • Keep track of the on/off and volume buttons when you take the phone apart because they are likely to fall out when the halves are separated.
  7. Remove the static tape covering the two connectors. Use a spudger to disconnect the battery cables from the motherboard. If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
    • Remove the static tape covering the two connectors.
    • Use a spudger to disconnect the battery cables from the motherboard.
    • If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
  8. Remove the disconnected battery from the phone.
    • Remove the disconnected battery from the phone.
  9. We will be removing these 3 ribbon cables. Using an opening pick, lift the grey tab on the rear camera's ZIF connector. Remove the ribbon cable and the camera.
    • We will be removing these 3 ribbon cables.
    • Using an opening pick, lift the grey tab on the rear camera's ZIF connector. Remove the ribbon cable and the camera.
    • Use tweezers to lift up on the grey latch on the ZIF connector.
    • Remove the ribbon cable from the ZIF connector.
  10. Use a pair of tweezers to lift up the black latch on the ZIF connector. Pull the ribbon cable out of the ZIF connector.
    • Use a pair of tweezers to lift up the black latch on the ZIF connector.
    • Pull the ribbon cable out of the ZIF connector.
  11. Using a metal spudger, work your way around the perimeter of the main board and screen. There is a lot of adhesive between the two pieces, so be careful to try to remove the adhesive slowly in order to not break anything. There is a lot of adhesive between the two pieces, so be careful to try to remove the adhesive slowly in order to not break anything.
    • Using a metal spudger, work your way around the perimeter of the main board and screen.
    • There is a lot of adhesive between the two pieces, so be careful to try to remove the adhesive slowly in order to not break anything.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Burke Seggerman
580 İtibar
5 adet Kılavuz yazıldı
Takım
Baylor, Team S3-G4, Williams Spring 2018 Baylor, Team S3-G4, Williams Spring 2018 üyesi
BU-WILLIAMS-S18S3G4
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 Gün: 17
Son 30 Gün: 63
Her zaman: 1,023
