Ana içeriğe geç
Droid MAXX 2 Screen Assembly Replacement
Neye ihtiyacın var
  1. Droid MAXX 2 Screen Assembly  Replacement, Battery: adım 1, 1 resimden 1.
    • Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
  2. Droid MAXX 2 Screen Assembly  Replacement: adım 2, 1 resimden 1.
    • Pull the sim card tray up out of the phone
  3. Droid MAXX 2 Screen Assembly  Replacement: adım 3, 2 resimden 1. Droid MAXX 2 Screen Assembly  Replacement: adım 3, 2 resimden 2.
    • Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
  4. Droid MAXX 2 Screen Assembly  Replacement: adım 4, 1 resimden 1.
    • Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
    • These may be T3 screws. If you are having trouble unscrewing these, stop and try a T3 bit.
  5. Droid MAXX 2 Screen Assembly  Replacement: adım 5, 1 resimden 1.
    • Pull the mid-frame off of the phone.
    • Keep track of the on/off and volume buttons when you take the phone apart because they are likely to fall out when the halves are separated.
  6. Droid MAXX 2 Screen Assembly  Replacement: adım 6, 3 resimden 1. Droid MAXX 2 Screen Assembly  Replacement: adım 6, 3 resimden 2. Droid MAXX 2 Screen Assembly  Replacement: adım 6, 3 resimden 3.
    • Remove the static tape covering the two connectors.
    • Use a spudger to disconnect the battery cables from the motherboard.
    • If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
  7. Droid MAXX 2 Screen Assembly  Replacement: adım 7, 1 resimden 1.
    • Remove the disconnected battery from the phone.
  8. Droid MAXX 2 Screen Assembly  Replacement, Screen Assembly: adım 8, 2 resimden 1. Droid MAXX 2 Screen Assembly  Replacement, Screen Assembly: adım 8, 2 resimden 2.
    Bu adımda kullanılan alet:
    • We will be removing these 3 ribbon cables.
    • Using an opening pick, lift the grey tab on the rear camera's ZIF connector. Remove the ribbon cable and the camera.
    • Use tweezers to lift up on the grey latch on the ZIF connector.
    • Remove the ribbon cable from the ZIF connector.
  9. Droid MAXX 2 Screen Assembly  Replacement: adım 9, 2 resimden 1. Droid MAXX 2 Screen Assembly  Replacement: adım 9, 2 resimden 2.
    • Use a pair of tweezers to lift up the black latch on the ZIF connector.
    • Pull the ribbon cable out of the ZIF connector.
  10. Droid MAXX 2 Screen Assembly  Replacement: adım 10, 3 resimden 1. Droid MAXX 2 Screen Assembly  Replacement: adım 10, 3 resimden 2. Droid MAXX 2 Screen Assembly  Replacement: adım 10, 3 resimden 3.
    • Using a metal spudger, work your way around the perimeter of the main board and screen.
    • There is a lot of adhesive between the two pieces, so be careful to try to remove the adhesive slowly in order to not break anything.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Burke Seggerman
704 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team S3-G4, Williams Spring 2018 Baylor, Team S3-G4, Williams Spring 2018 üyesi
BU-WILLIAMS-S18S3G4
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 47
Her zaman: 2,346
