Ana içeriğe geç
Droid Ultra XT1080 Battery Replacement
Neye ihtiyacın var
  1. Droid Ultra XT1080 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the SIM card tray from the side of the device using a plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  2. Droid Ultra XT1080 Battery Replacement: adım 2, 1 resimden 1.
    • After properly removing the SIM card tray take your spudger and press it in between the plastic case and the frame of the device until you hear a snap.
    • Work your way from the top and the other side to confirm all the clips are disconnected.
    • Be gentle when performing this so you don't crack or break the plastic.
    FixBot'a Sor
    Yorum Ekle
  3. Droid Ultra XT1080 Battery Replacement: adım 3, 1 resimden 1.
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
    FixBot'a Sor
    Yorum Ekle
  4. Droid Ultra XT1080 Battery Replacement: adım 4, 2 resimden 1. Droid Ultra XT1080 Battery Replacement: adım 4, 2 resimden 2.
    • After the top and bottom screws are removed remove the top and bottom plastic pieces that were secured to the device.
    FixBot'a Sor
    Yorum Ekle
  5. Droid Ultra XT1080 Battery Replacement: adım 5, 1 resimden 1.
    • Begin to gently pry up the battery from the frame with a plastic opening tool to release it from its adhesive securing.
    FixBot'a Sor
    Yorum Ekle
  6. Droid Ultra XT1080 Battery Replacement: adım 6, 1 resimden 1.
    • Remove the four T5 Torx screws securing the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. Droid Ultra XT1080 Battery Replacement: adım 7, 2 resimden 1. Droid Ultra XT1080 Battery Replacement: adım 7, 2 resimden 2.
    • Gently pry the motherboard out of the frame using the nylon spudger.
    • Make sure not to damage the LCD cable in the process.
    FixBot'a Sor
    Yorum Ekle
  8. Droid Ultra XT1080 Battery Replacement: adım 8, 1 resimden 1.
    • Disconnect the LCD cable with a spudger from the motherboard by gently lifting up the two connectors.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
knoyes
785 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G8, Peak Fall 2018 UMass Dartmouth, Team S3-G8, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S3G8
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 40
Her zaman: 3,448
