Ana içeriğe geç
Droid Ultra XT1080 Charging Port Replacement
Neye ihtiyacın var
  1. Droid Ultra XT1080 Charging Port  Replacement, Charging Port: adım 1, 1 resimden 1.
    • Remove SIM card tray from the device with a plastic opening tool.
  2. Droid Ultra XT1080 Charging Port  Replacement: adım 2, 1 resimden 1.
    • Once SIM card tray is removed press the spudger between the plastic case and the frame of the device until you hear a snap.
    • Work your away around the device until all the plastic clips are undone.
    • Be gentle with the plastic to make sure it doesn't break.
  3. Droid Ultra XT1080 Charging Port  Replacement: adım 3, 1 resimden 1.
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
  4. Droid Ultra XT1080 Charging Port  Replacement: adım 4, 2 resimden 1. Droid Ultra XT1080 Charging Port  Replacement: adım 4, 2 resimden 2.
    • Once the screws are removed, use a plastic spudger and lift up the two plastic pieces that were secured by the screws.
  5. Droid Ultra XT1080 Charging Port  Replacement: adım 5, 1 resimden 1.
    • Remove the four T5 Torx screws securing the motherboard.
  6. Droid Ultra XT1080 Charging Port  Replacement: adım 6, 1 resimden 1.
    • Gently pry the motherboard out of the frame of the device.
  7. Droid Ultra XT1080 Charging Port  Replacement: adım 7, 2 resimden 1. Droid Ultra XT1080 Charging Port  Replacement: adım 7, 2 resimden 2.
    • Once the motherboard is free flip it over on its back so all the components are showing.
  8. Droid Ultra XT1080 Charging Port  Replacement: adım 8, 1 resimden 1.
    • To fully replace the charging port you need to desolder the port and solder a new one in.
Sonuç
Bir başkası bu kılavuzu tamamladı.
knoyes
785 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G8, Peak Fall 2018 UMass Dartmouth, Team S3-G8, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S3G8
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 925
