Ana içeriğe geç
Droid Ultra XT1080 Front assembly with frame Replacement
Neye ihtiyacın var
  1. Droid Ultra XT1080 Front assembly with frame Replacement, Front assembly with frame: adım 1, 1 resimden 1.
    • Start by removing the Sim card tray, which also happens to be your volume button
  2. Droid Ultra XT1080 Front assembly with frame Replacement: adım 2, 1 resimden 1.
    • I personally used an iSesamo tool to unclip the tabs off the back housing, You can also use the Jimmy or some plastic prying tools.
    • Do Not pry the back housing around the bottom of the screen. Pry on the left, right, and top. After that the back housing should slide off on the bottom.
  3. Droid Ultra XT1080 Front assembly with frame Replacement: adım 3, 3 resimden 1. Droid Ultra XT1080 Front assembly with frame Replacement: adım 3, 3 resimden 2. Droid Ultra XT1080 Front assembly with frame Replacement: adım 3, 3 resimden 3.
    • T5 Torx screws
    • T3 Torx screw
    • T5 Torx screws
    • T5 Torx screws
    • When putting back together, do not tighten the screws too tight.
  4. Droid Ultra XT1080 Front assembly with frame Replacement: adım 4, 1 resimden 1.
    • T5 Torx screws
  5. Droid Ultra XT1080 Front assembly with frame Replacement: adım 5, 2 resimden 1. Droid Ultra XT1080 Front assembly with frame Replacement: adım 5, 2 resimden 2.
    • T5 Torx screws
  6. Droid Ultra XT1080 Front assembly with frame Replacement: adım 6, 3 resimden 1. Droid Ultra XT1080 Front assembly with frame Replacement: adım 6, 3 resimden 2. Droid Ultra XT1080 Front assembly with frame Replacement: adım 6, 3 resimden 3.
    • With the iSesamo tool, or a prying tool, unclip the tabs on the left and right side of the phone.
  7. Droid Ultra XT1080 Front assembly with frame Replacement: adım 7, 3 resimden 1. Droid Ultra XT1080 Front assembly with frame Replacement: adım 7, 3 resimden 2. Droid Ultra XT1080 Front assembly with frame Replacement: adım 7, 3 resimden 3.
    • Using a Spudger lift the motherboard from right to left.
    • After lifting the motherboard from the frame remove the tape, and lift the black tab with your Spudger to remove the flex cable.
    • When you place the new screen remember to replace the tape over the flex cable.
    • Before putting the mother board on remember to transfer your ear speaker from the old frame to the new one.
  8. Droid Ultra XT1080 Front assembly with frame Replacement, And you are done...: adım 8, 1 resimden 1.
    • .... as long as you work your way backwards to put it back together.
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
Ricardo Martinez
751 İtibar
1 Kılavuz yazıldı
8Kılavuz Yorumları
I want to repair the scencor
Atihussan82 Hussain - Yanıt
I want to repair the XT1080 sciencer
Repair screen on droid ultra XT 1080
churchy dezign - Yanıt
I want to repair the camera on Droid turbo XT1080
King Bash - Yanıt
My Android 1080 screen is frozen. How can I get my photos?
Madeline Rutledge - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 26
Her zaman: 4,992
