Ana içeriğe geç
Droid Ultra XT1080 Screen Replacement
Neye ihtiyacın var
  1. Droid Ultra XT1080 Screen Replacement, Screen: adım 1, 3 resimden 1. Droid Ultra XT1080 Screen Replacement, Screen: adım 1, 3 resimden 2. Droid Ultra XT1080 Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Gently remove SIM card tray from device using a metal spudger.
  2. Droid Ultra XT1080 Screen Replacement: adım 2, 1 resimden 1.
    • After SIM card tray is removed press the spudger between the plastic case and the frame of the device until you hear a snap.
    • Work your way around the device until all the clips are undone.
    • Be gentle with the plastic to make sure it doesn't crack or break.
  3. Droid Ultra XT1080 Screen Replacement: adım 3, 1 resimden 1.
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
  4. Droid Ultra XT1080 Screen Replacement: adım 4, 2 resimden 1. Droid Ultra XT1080 Screen Replacement: adım 4, 2 resimden 2.
    • Once the screws are removed, use a nylon spudger and lift up on the two plastic pieces that were secured by the screws.
  5. Droid Ultra XT1080 Screen Replacement: adım 5, 2 resimden 1. Droid Ultra XT1080 Screen Replacement: adım 5, 2 resimden 2.
    • Remove the four T5 Torx screws securing the motherboard.
  6. Droid Ultra XT1080 Screen Replacement: adım 6, 1 resimden 1.
    • Gently pry the motherboard out of the frame using the plastic opening tool.
  7. Droid Ultra XT1080 Screen Replacement: adım 7, 2 resimden 1. Droid Ultra XT1080 Screen Replacement: adım 7, 2 resimden 2.
    • Once motherboard is removed you have successfully removed the screen from the device.
Sonuç
knoyes
785 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G8, Peak Fall 2018 UMass Dartmouth, Team S3-G8, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S3G8
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 40
Her zaman: 960
