Ana içeriğe geç
DualSense Controller V5 Buttons Replacement
Neye ihtiyacın var
    1. DualSense Controller V5 Buttons Replacement, Unclip the right end of the middle trim: adım 1, 2 resimden 1. DualSense Controller V5 Buttons Replacement, Unclip the right end of the middle trim: adım 1, 2 resimden 2.
      • Disconnect and power down your controller before you begin.
      • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
      FixBot'a Sor
      Yorum Ekle
    2. DualSense Controller V5 Buttons Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 1. DualSense Controller V5 Buttons Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 2. DualSense Controller V5 Buttons Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 3.
      • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
      FixBot'a Sor
      Yorum Ekle
    3. DualSense Controller V5 Buttons Replacement, Unclip the left end of the middle trim: adım 3, 2 resimden 1. DualSense Controller V5 Buttons Replacement, Unclip the left end of the middle trim: adım 3, 2 resimden 2.
      • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
      FixBot'a Sor
      Yorum Ekle
    4. DualSense Controller V5 Buttons Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 1. DualSense Controller V5 Buttons Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 2. DualSense Controller V5 Buttons Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 3.
      • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
      FixBot'a Sor
      Yorum Ekle
    5. DualSense Controller V5 Buttons Replacement, Remove the middle trim: adım 5, 3 resimden 1. DualSense Controller V5 Buttons Replacement, Remove the middle trim: adım 5, 3 resimden 2. DualSense Controller V5 Buttons Replacement, Remove the middle trim: adım 5, 3 resimden 3.
      • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
      • Lift the middle trim over the joysticks to remove it.
      FixBot'a Sor
      Yorum Ekle
    1. DualSense Controller V5 Buttons Replacement, Remove the L1 button: adım 6, 3 resimden 1. DualSense Controller V5 Buttons Replacement, Remove the L1 button: adım 6, 3 resimden 2. DualSense Controller V5 Buttons Replacement, Remove the L1 button: adım 6, 3 resimden 3.
      • With one hand, grip the controller and use your thumb to hold down the left trigger.
      • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
      • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
      FixBot'a Sor
      Yorum Ekle
    2. DualSense Controller V5 Buttons Replacement, Remove the R1 button: adım 7, 3 resimden 1. DualSense Controller V5 Buttons Replacement, Remove the R1 button: adım 7, 3 resimden 2. DualSense Controller V5 Buttons Replacement, Remove the R1 button: adım 7, 3 resimden 3.
      • Repeat the previous step to remove the R1 button.
      FixBot'a Sor
      Yorum Ekle
    1. DualSense Controller V5 Buttons Replacement, Remove the rear case screws: adım 8, 2 resimden 1. DualSense Controller V5 Buttons Replacement, Remove the rear case screws: adım 8, 2 resimden 2.
      • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
      FixBot'a Sor
      Yorum Ekle
    2. DualSense Controller V5 Buttons Replacement: adım 9, 2 resimden 1. DualSense Controller V5 Buttons Replacement: adım 9, 2 resimden 2.
      • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
      FixBot'a Sor
      Yorum Ekle
    3. DualSense Controller V5 Buttons Replacement, Separate the rear case: adım 10, 3 resimden 1. DualSense Controller V5 Buttons Replacement, Separate the rear case: adım 10, 3 resimden 2. DualSense Controller V5 Buttons Replacement, Separate the rear case: adım 10, 3 resimden 3.
      • Be gentle when releasing the rear cover clips—they're delicate and can easily break.
      • Use the point of a spudger to release the two clips on either side of the headset jack.
      FixBot'a Sor
      Yorum Ekle
    4. DualSense Controller V5 Buttons Replacement: adım 11, 3 resimden 1. DualSense Controller V5 Buttons Replacement: adım 11, 3 resimden 2. DualSense Controller V5 Buttons Replacement: adım 11, 3 resimden 3.
      • Tight plastic clips secure the left and right edges of the rear case.
      • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
      • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
      FixBot'a Sor
      Yorum Ekle
    5. DualSense Controller V5 Buttons Replacement: adım 12, 3 resimden 1. DualSense Controller V5 Buttons Replacement: adım 12, 3 resimden 2. DualSense Controller V5 Buttons Replacement: adım 12, 3 resimden 3.
      • Repeat the previous step on the right edge to release its clips.
      FixBot'a Sor
      Yorum Ekle
    6. DualSense Controller V5 Buttons Replacement: adım 13, 2 resimden 1. DualSense Controller V5 Buttons Replacement: adım 13, 2 resimden 2.
      • Lay your controller upside down so the joysticks are on your work surface.
      • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
      FixBot'a Sor
      Yorum Ekle
    1. DualSense Controller V5 Buttons Replacement, Remove the rear case: adım 14, 1 resimden 1.
      • Remove the rear case.
      FixBot'a Sor
      Yorum Ekle
    1. DualSense Controller V5 Buttons Replacement, Disconnect the battery: adım 15, 2 resimden 1. DualSense Controller V5 Buttons Replacement, Disconnect the battery: adım 15, 2 resimden 2.
      • Don't try to fully remove the battery, as it's still connected to the controller by delicate cables.
      • Swing the battery out of its recess so you can access its connector, making sure to not strain the cables.
      • Keep the battery supported so it doesn't fall during the next step.
      FixBot'a Sor
      Yorum Ekle
    2. DualSense Controller V5 Buttons Replacement: adım 16, 3 resimden 1. DualSense Controller V5 Buttons Replacement: adım 16, 3 resimden 2. DualSense Controller V5 Buttons Replacement: adım 16, 3 resimden 3.
      • Use a pair of angled tweezers to firmly grip the short sides of the battery connector.
      • To get a stronger hold on the connector, grip the tweezers as close to the connector as you can.
      • Rock the connector side‑to‑side to walk it out of its socket and disconnect it.
      FixBot'a Sor
      Yorum Ekle
    3. DualSense Controller V5 Buttons Replacement, Remove the battery: adım 17, 1 resimden 1.
      • Remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. DualSense Controller V5 Buttons Replacement, Remove the lower microphone: adım 18, 2 resimden 1. DualSense Controller V5 Buttons Replacement, Remove the lower microphone: adım 18, 2 resimden 2.
      • Use tweezers to grip the lower microphone cable's plastic tab and pull it straight out of the socket to remove the microphone.
      • During reassembly, make sure the microphone has its rubber gasket and that the alignment tab goes into its cutout.
      FixBot'a Sor
      Yorum Ekle
    2. DualSense Controller V5 Buttons Replacement, Remove the battery bracket: adım 19, 2 resimden 1. DualSense Controller V5 Buttons Replacement, Remove the battery bracket: adım 19, 2 resimden 2.
      • Use a Phillips screwdriver to remove the 6.5 mm‑long screw securing the battery bracket.
      FixBot'a Sor
      Yorum Ekle
    3. DualSense Controller V5 Buttons Replacement: adım 20, 2 resimden 1. DualSense Controller V5 Buttons Replacement: adım 20, 2 resimden 2.
      • Remove the battery bracket.
      FixBot'a Sor
      Yorum Ekle
    4. DualSense Controller V5 Buttons Replacement, Disconnect the motherboard: adım 21, 2 resimden 1. DualSense Controller V5 Buttons Replacement, Disconnect the motherboard: adım 21, 2 resimden 2.
      • Use tweezers to grip the hard plastic section of the right trigger ribbon cable and pull the cable straight out of its socket to disconnect it.
      • If you're having trouble, try gripping the tweezers as close to the cable as possible to get a better hold.
      FixBot'a Sor
      Yorum Ekle
    5. DualSense Controller V5 Buttons Replacement: adım 22, 3 resimden 1. DualSense Controller V5 Buttons Replacement: adım 22, 3 resimden 2. DualSense Controller V5 Buttons Replacement: adım 22, 3 resimden 3.
      FixBot'a Sor
      Yorum Ekle
    6. DualSense Controller V5 Buttons Replacement, Reposition the motherboard: adım 23, 2 resimden 1. DualSense Controller V5 Buttons Replacement, Reposition the motherboard: adım 23, 2 resimden 2.
      • Throughout the rest of your repair, be very careful not to strain the delicate wires attached to the bottom edge of the board. They can easily tear, requiring soldering to fix them.
      • Use your fingers to gently push the joysticks through their cutouts on the shell to separate the motherboard.
      FixBot'a Sor
      Yorum Ekle
    7. DualSense Controller V5 Buttons Replacement: adım 24, 2 resimden 1. DualSense Controller V5 Buttons Replacement: adım 24, 2 resimden 2.
      • Carefully flip the motherboard down so the joysticks are facing up.
      FixBot'a Sor
      Yorum Ekle
    1. DualSense Controller V5 Buttons Replacement, Remove the speaker: adım 25, 3 resimden 1. DualSense Controller V5 Buttons Replacement, Remove the speaker: adım 25, 3 resimden 2. DualSense Controller V5 Buttons Replacement, Remove the speaker: adım 25, 3 resimden 3.
      FixBot'a Sor
      Yorum Ekle
    1. DualSense Controller V5 Buttons Replacement, Remove the midframe: adım 26, 3 resimden 1. DualSense Controller V5 Buttons Replacement, Remove the midframe: adım 26, 3 resimden 2. DualSense Controller V5 Buttons Replacement, Remove the midframe: adım 26, 3 resimden 3.
      • Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the midframe.
      FixBot'a Sor
      Yorum Ekle
    2. DualSense Controller V5 Buttons Replacement: adım 27, 3 resimden 1. DualSense Controller V5 Buttons Replacement: adım 27, 3 resimden 2. DualSense Controller V5 Buttons Replacement: adım 27, 3 resimden 3.
      • Carefully lift the midframe and motherboard up and out of the front case.
      FixBot'a Sor
      Yorum Ekle
    1. DualSense Controller V5 Buttons Replacement, Remove the buttons: adım 28, 3 resimden 1. DualSense Controller V5 Buttons Replacement, Remove the buttons: adım 28, 3 resimden 2. DualSense Controller V5 Buttons Replacement, Remove the buttons: adım 28, 3 resimden 3.
      • Use tweezers or your fingers to remove the Options and Create buttons.
      FixBot'a Sor
      Yorum Ekle
    2. DualSense Controller V5 Buttons Replacement: adım 29, 3 resimden 1. DualSense Controller V5 Buttons Replacement: adım 29, 3 resimden 2. DualSense Controller V5 Buttons Replacement: adım 29, 3 resimden 3.
      • Use tweezers or your fingers to remove the three silicone pads covering the Action, PS, and Directional buttons.
      FixBot'a Sor
      Yorum Ekle
    3. DualSense Controller V5 Buttons Replacement: adım 30, 3 resimden 1. DualSense Controller V5 Buttons Replacement: adım 30, 3 resimden 2. DualSense Controller V5 Buttons Replacement: adım 30, 3 resimden 3.
      • Use tweezers or your fingers to remove the Action, PS, and Directional buttons.
      • Alternatively, you can slowly flip the front case over to let the buttons fall out.
      • During reassembly, use the alignment tabs to orient each button into its recess—each one is keyed specifically for its recess and proper orientation.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Spencer Day
197.661 İtibar
1.243 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
41.818 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 25
Son 7 gün: 163
Son 30 gün: 626
Her zaman: 5,056
