Ana içeriğe geç
DualSense Controller V5 Middle Trim Replacement
Neye ihtiyacın var
  1. DualSense Controller V5 Middle Trim Replacement, Unclip the right end of the middle trim: adım 1, 2 resimden 1. DualSense Controller V5 Middle Trim Replacement, Unclip the right end of the middle trim: adım 1, 2 resimden 2.
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. DualSense Controller V5 Middle Trim Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 1. DualSense Controller V5 Middle Trim Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 2. DualSense Controller V5 Middle Trim Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 3.
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. DualSense Controller V5 Middle Trim Replacement, Unclip the left end of the middle trim: adım 3, 2 resimden 1. DualSense Controller V5 Middle Trim Replacement, Unclip the left end of the middle trim: adım 3, 2 resimden 2.
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. DualSense Controller V5 Middle Trim Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 1. DualSense Controller V5 Middle Trim Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 2. DualSense Controller V5 Middle Trim Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 3.
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. DualSense Controller V5 Middle Trim Replacement, Remove the middle trim: adım 5, 3 resimden 1. DualSense Controller V5 Middle Trim Replacement, Remove the middle trim: adım 5, 3 resimden 2. DualSense Controller V5 Middle Trim Replacement, Remove the middle trim: adım 5, 3 resimden 3.
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Spencer Day
150.037 İtibar
995 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.640 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 35
Her zaman: 217
