Ana içeriğe geç
DualSense Controller V5 Rear Case Replacement
Neye ihtiyacın var
  1. DualSense Controller V5 Rear Case Replacement, Unclip the right end of the middle trim: adım 1, 2 resimden 1. DualSense Controller V5 Rear Case Replacement, Unclip the right end of the middle trim: adım 1, 2 resimden 2.
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. DualSense Controller V5 Rear Case Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 1. DualSense Controller V5 Rear Case Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 2. DualSense Controller V5 Rear Case Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 3.
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. DualSense Controller V5 Rear Case Replacement, Unclip the left end of the middle trim: adım 3, 2 resimden 1. DualSense Controller V5 Rear Case Replacement, Unclip the left end of the middle trim: adım 3, 2 resimden 2.
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. DualSense Controller V5 Rear Case Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 1. DualSense Controller V5 Rear Case Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 2. DualSense Controller V5 Rear Case Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 3.
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. DualSense Controller V5 Rear Case Replacement, Remove the middle trim: adım 5, 3 resimden 1. DualSense Controller V5 Rear Case Replacement, Remove the middle trim: adım 5, 3 resimden 2. DualSense Controller V5 Rear Case Replacement, Remove the middle trim: adım 5, 3 resimden 3.
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
  6. DualSense Controller V5 Rear Case Replacement, Remove the L1 button: adım 6, 3 resimden 1. DualSense Controller V5 Rear Case Replacement, Remove the L1 button: adım 6, 3 resimden 2. DualSense Controller V5 Rear Case Replacement, Remove the L1 button: adım 6, 3 resimden 3.
    • With one hand, grip the controller and use your thumb to hold down the left trigger.
    • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
    • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
  7. DualSense Controller V5 Rear Case Replacement, Remove the R1 button: adım 7, 3 resimden 1. DualSense Controller V5 Rear Case Replacement, Remove the R1 button: adım 7, 3 resimden 2. DualSense Controller V5 Rear Case Replacement, Remove the R1 button: adım 7, 3 resimden 3.
    • Repeat the previous step to remove the R1 button.
  8. DualSense Controller V5 Rear Case Replacement, Remove the rear case screws: adım 8, 2 resimden 1. DualSense Controller V5 Rear Case Replacement, Remove the rear case screws: adım 8, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
  9. DualSense Controller V5 Rear Case Replacement: adım 9, 2 resimden 1. DualSense Controller V5 Rear Case Replacement: adım 9, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
  10. DualSense Controller V5 Rear Case Replacement, Separate the rear case: adım 10, 3 resimden 1. DualSense Controller V5 Rear Case Replacement, Separate the rear case: adım 10, 3 resimden 2. DualSense Controller V5 Rear Case Replacement, Separate the rear case: adım 10, 3 resimden 3.
    • Be gentle when releasing the rear cover clips—they're delicate and can easily break.
    • Use the point of a spudger to release the two clips on either side of the headset jack.
  11. DualSense Controller V5 Rear Case Replacement: adım 11, 3 resimden 1. DualSense Controller V5 Rear Case Replacement: adım 11, 3 resimden 2. DualSense Controller V5 Rear Case Replacement: adım 11, 3 resimden 3.
    • Tight plastic clips secure the left and right edges of the rear case.
    • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
    • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
  12. DualSense Controller V5 Rear Case Replacement: adım 12, 3 resimden 1. DualSense Controller V5 Rear Case Replacement: adım 12, 3 resimden 2. DualSense Controller V5 Rear Case Replacement: adım 12, 3 resimden 3.
    • Repeat the previous step on the right edge to release its clips.
  13. DualSense Controller V5 Rear Case Replacement: adım 13, 2 resimden 1. DualSense Controller V5 Rear Case Replacement: adım 13, 2 resimden 2.
    • Lay your controller upside down so the joysticks are on your work surface.
    • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
  14. DualSense Controller V5 Rear Case Replacement, Remove the rear case: adım 14, 1 resimden 1.
    • Remove the rear case.
Sonuç
Spencer Day
150.037 İtibar
995 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.648 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 81
Her zaman: 545
