Ana içeriğe geç
DualSense Edge Front Trim Replacement
Neye ihtiyacın var
  1. DualSense Edge Front Trim Replacement, Remove the front trim: adım 1, 3 resimden 1. DualSense Edge Front Trim Replacement, Remove the front trim: adım 1, 3 resimden 2. DualSense Edge Front Trim Replacement, Remove the front trim: adım 1, 3 resimden 3.
    • Place the controller on a work surface with the joysticks facing down.
    • Use a spudger or your finger to slide the Release tab to the left. The front trim should fall to the table.
    • If the front trim doesn't fall open, make sure the front trim has room to fall down and the Release tab is pushed all the way to the left.
    • Lift the controller up, leaving the front trim on the table.
    • During reassembly, insert the front trim at an angle so the top slots in first, then lower the trim into place and snap it onto the controller.
Sonuç
Spencer Pennington
17.530 İtibar
114 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
120 Üyeler
19.664 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 66
Her zaman: 255
