Ana içeriğe geç
DualShock 2 D-Pad Replacement
Neye ihtiyacın var
  1. DualShock 2 D-Pad Replacement, D-Pad: adım 1, 3 resimden 1. DualShock 2 D-Pad Replacement, D-Pad: adım 1, 3 resimden 2. DualShock 2 D-Pad Replacement, D-Pad: adım 1, 3 resimden 3.
    • Turn the controller over.
    • Unscrew the six screws using your Phillips #00 screwdriver.
  2. DualShock 2 D-Pad Replacement: adım 2, 3 resimden 1. DualShock 2 D-Pad Replacement: adım 2, 3 resimden 2. DualShock 2 D-Pad Replacement: adım 2, 3 resimden 3.
    • Remove the back cover from the controller.
    • Slide the triggers off by pulling the trigger off the controller and repeat for another side.
  3. DualShock 2 D-Pad Replacement: adım 3, 3 resimden 1. DualShock 2 D-Pad Replacement: adım 3, 3 resimden 2. DualShock 2 D-Pad Replacement: adım 3, 3 resimden 3.
    • Remove the circuit board carefully.
    • Make sure not to touch any vital components and only grab them by the side.
  4. DualShock 2 D-Pad Replacement: adım 4, 3 resimden 1. DualShock 2 D-Pad Replacement: adım 4, 3 resimden 2. DualShock 2 D-Pad Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the yellow rubber from the D-pad.
    • Remove the black plastic bracket with a pair of tweezers.
  5. DualShock 2 D-Pad Replacement: adım 5, 3 resimden 1. DualShock 2 D-Pad Replacement: adım 5, 3 resimden 2. DualShock 2 D-Pad Replacement: adım 5, 3 resimden 3.
    • Remove the broken D-pad from the controller carefully.
  6. DualShock 2 D-Pad Replacement: adım 6, 3 resimden 1. DualShock 2 D-Pad Replacement: adım 6, 3 resimden 2. DualShock 2 D-Pad Replacement: adım 6, 3 resimden 3.
    • Put the replacement D-pad in the controller.
    • Make sure to get replacement parts designed for your controller as sizes may vary.
    • Put the plastic bracket back on carefully.
  7. DualShock 2 D-Pad Replacement: adım 7, 3 resimden 1. DualShock 2 D-Pad Replacement: adım 7, 3 resimden 2. DualShock 2 D-Pad Replacement: adım 7, 3 resimden 3.
    • Replace the yellow rubber.
    • Carefully insert the circuit board and reclip the triggers.
    • Make sure to insert the analog sticks through the designed opening.
    • Insert the back cover back in place.
  8. DualShock 2 D-Pad Replacement: adım 8, 3 resimden 1. DualShock 2 D-Pad Replacement: adım 8, 3 resimden 2. DualShock 2 D-Pad Replacement: adım 8, 3 resimden 3.
    • Screw the back cover on again clockwise.
    • Test D-pad to make sure its in working order.
Sonuç
Enjoy your new D-pad.
5 farklı kişi bu kılavuzu tamamladı.
Gilberto Rosales
274 İtibar
1 Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 3-77, Briggs Fall 2022 CSU Los Angeles, Team 3-77, Briggs Fall 2022 üyesi
CSULA-BRIGGS-F22S3G77
1 Üye
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 82
Son 30 gün: 392
Her zaman: 4,867
