Ana içeriğe geç
DualShock 2 Disassembly
Neye ihtiyacın var
  1. DualShock 2 Disassembly, DualShock 2 Disassembly: adım 1, 2 resimden 1. DualShock 2 Disassembly, DualShock 2 Disassembly: adım 1, 2 resimden 2.
    • First, check that the connection port of your controller (whether wireless or not) has all the pins.
    • If you have a wired controller (a controller with a cable that connects directly to your console) try bending it in different directions. This may reconnect broken connections within the controller cable and could be a temporary fix.
    FixBot'a Sor
    Yorum Ekle
  2. DualShock 2 Disassembly: adım 2, 2 resimden 1. DualShock 2 Disassembly: adım 2, 2 resimden 2.
    • Flip Over Controller and remove all 6 screws from the bottom of the controller.
    FixBot'a Sor
    Yorum Ekle
  3. DualShock 2 Disassembly: adım 3, 2 resimden 1. DualShock 2 Disassembly: adım 3, 2 resimden 2.
    • Once the screws are removed, carefully pry the controller open with your hands.
    • Remove the screw holding the circuit board in place.
    FixBot'a Sor
    Yorum Ekle
  4. DualShock 2 Disassembly: adım 4, 1 resimden 1.
    • Carefully remove the circuit board from the front cover of the controller.
    FixBot'a Sor
    Yorum Ekle
  5. DualShock 2 Disassembly: adım 5, 1 resimden 1.
    • Analyze the rubber pads for any debris that may be getting in the way of the black pads. These make an electrical connection on the pad and may not be contacting properly.
    FixBot'a Sor
    Yorum Ekle
  6. DualShock 2 Disassembly: adım 6, 1 resimden 1.
    • Examine the flexible trigger board itself for any dirt or debris that could get in the rubber button pad's way.
    FixBot'a Sor
    Yorum Ekle
  7. DualShock 2 Disassembly: adım 7, 1 resimden 1.
    • Check the connection of the flexible trigger board to the main circuit board of your controller.
    FixBot'a Sor
    Yorum Ekle
  8. DualShock 2 Disassembly: adım 8, 1 resimden 1.
    • If the previous steps are all covered and you are still facing difficulties in getting your buttons to work, consider replacing the main circuit board or flexible trigger board.
    FixBot'a Sor
    Yorum Ekle
  9. DualShock 2 Disassembly: adım 9, 1 resimden 1.
    • Reverse the disassembly steps until the controller is back to its original state. Plug the controller into the console and test whether the fix worked.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
48 farklı kişi bu kılavuzu tamamladı.
Peder Hertel
1.503 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 17-5, Green Fall 2015 Cal Poly, Team 17-5, Green Fall 2015 üyesi
CPSU-GREEN-F15S17G5
4 Üyeler
12 adet Kılavuz yazıldı
7Kılavuz Yorumları
Dualshock 2 controllers, model A and H, are having 8 pins, not 9. Your first Step is false and rarely wires are the cause of the problem.
Eva Langley - Yanıt Paylaş
No my Dual-shock 2 controller has 9 pins so you are wrong he is right man.
Adam Bolyard - Yanıt Paylaş
Eva Langley is correct, some of these controllers have only 8 pins, not 9. I myself can conformed this because I just recently opened one of two brand new fresh out of the box Sony original equipment controllers that I purchased (for a little less than $10 a piece) during a clearance sale at my local Sears just before they went out of business. So Eva is NOT wrong. I still have the second one still in the box and before anyone ask, I don’t won’t to sale. I purchased them because I have had both my original controllers go out after they were sitting up for a few years without use. My game units are very well taken care of but the controllers of the PS2 just stopped working and finding a definitive answer to why this happens is STILL very elusive in 2019.
byordsilp - Yanıt Paylaş
After opening one of these, the R2 and L2 buttons don't feel right, is there a way to fix this?
Fridtjof Riibe - Yanıt Paylaş
Try to put R2 and L2 after you close the shell. The buttons have clips that hold on position after you insert them .
Alex SC - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 26
Son 7 gün: 184
Son 30 gün: 962
Her zaman: 86,636
