Ana içeriğe geç
DualShock 2 Wireless Controller Analog Stick Replacement
Neye ihtiyacın var
  1. DualShock 2 Wireless Controller Analog Stick Replacement, Analog Stick: adım 1, 2 resimden 1. DualShock 2 Wireless Controller Analog Stick Replacement, Analog Stick: adım 1, 2 resimden 2.
    • Remove the six 7.8 mm anchoring screws from the back casing of the controller using a Phillips #0 screwdriver.
  2. DualShock 2 Wireless Controller Analog Stick Replacement: adım 2, 2 resimden 1. DualShock 2 Wireless Controller Analog Stick Replacement: adım 2, 2 resimden 2.
    • Pull apart the outer casing by hand, or by using a plastic opening tool, from the bottom of the controller.
    • Be mindful not to sever the connection between the battery pack attached to the back casing and the internal board
  3. DualShock 2 Wireless Controller Analog Stick Replacement: adım 3, 2 resimden 1. DualShock 2 Wireless Controller Analog Stick Replacement: adım 3, 2 resimden 2.
    • Remove the two 6.1 mm screws holding the internal analog stick board and the front of the controller together.
  4. DualShock 2 Wireless Controller Analog Stick Replacement: adım 4, 2 resimden 1. DualShock 2 Wireless Controller Analog Stick Replacement: adım 4, 2 resimden 2.
    • Lift the analog stick board away from the front of the controller.
    • Remove the detached or loose analog stick for realignment.
  5. DualShock 2 Wireless Controller Analog Stick Replacement: adım 5, 1 resimden 1.
    • Realign the analog stick by pushing the removed stick back into its chassis with focus on pushing it in at the new, desired resting angle. You should feel or hear a small click if done correctly.
    • The stick may not immediately click into place under the pressure. Instead of pushing harder, try rotating the stick 90 degrees and pushing down again.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Roger Campbell
289 İtibar
1 Kılavuz yazıldı
Ekip
Texas Tech, Team S1-G1, Rauch Summer 2017 Texas Tech, Team S1-G1, Rauch Summer 2017 üyesi
TTU-RAUCH-SU17S1G1
2 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 44
Son 30 gün: 202
Her zaman: 12,212
